I’m looking for some advise with my Audi A4 B8 2008 2.0 TFSI 104k miles. Car’s battery isn’t charging up as well as I’d expect it to and it feels like it’s getting worse lately. For a while I was hoping it’s simply because I don’t do a lot of long trips but last week, did a 4h long drive on the motorway and according to MMI the battery was only 30% charged after it. This is making me suspect that there’s something wrong with the alternator or charging system rather than battery or parasitic draw.
Things I’ve checked so far:
- Car battery is around a year old, Varta Silver Dynamic 77 AH
- I’ve taken the battery out to charge it up using a battery charger and it charged up fine, went to 12.6V and MMI recognised it properly
- I’ve coded in the battery using VCDS as per this guide
- No alternator/battery related error codes present but I can dump a full scan log tomorrow.
Today I thought I’d go outside and have another go and figuring out what the issue could be. When looking at measuring block for CAN gateway module, I noticed that the CAN gateway is requesting 15V from the alternator, but the measuring blocks are only reporting 13.3V which seemed quite strange to me. I checked the voltage between the jump-start points and measured 13.3V, exactly as reported by the CAN. 0.02 V between alternator housing and negative jumpstart terminal. I couldn’t see clearly at first where the alternator positive output terminal was but then figured out it’s the nut on the back side of it. Measured 14.8V between the alternator + terminal and negative jumpstart terminal which makes me think that actually the alternator is working fine but there’s an issue elsewhere. Found a 1.5V drop between alternator positive and jumpstart positive terminal.
I feel like I’m getting somewhere with this now – this 1.5V drop makes me think that there’s some faulty connection along the cable.
Any thoughts what would be the next best move? I’m thinking of either jumping the connection or looking and replacing the cables.
