Results 1 to 32 of 32
    Veteran Member Four Rings gpxluke's Avatar
    Feb 14 2006
    Vancouver
    Luke's B9.5 RS4 Build Thread (a lot of pics)
    So it has been a while (I believe more than 10 years) since my last post to the community as I sold my B7 a long long time ago, I did not spend too much time visiting the forum ever since. I guess it's time to share my story with the new B9.5 RS4. Owning an avant has always been on my mind since I sold my B7 A4 sedan as I believe Audi still makes the best looking wagon in the market, I started looking to get a new one in Feb 2023 and found one with very minimal options (no drc, with sport exhaust only). I pulled the trigger and got the paperwork done. Car arrived in March, 2023.
    So let the modification begin for the B9.5 RS4. The first mod I did was the wheels. I ordered a set of custom spec forged ABT style wheels with relatively conservative spec 20X10 ET22 (I did put a 10mm spacers later on to make them look more flush). I also added a Karbel roof spoiler on the car at the same time.
    BMC air filter + larger turbo inlet came to my next mod to my list.
    After owning a BMW 3 series for couple years, I have been in love with the responsive handling that RWD car has. I decided to put more effort in improving the RS4 chassis + suspension to make it a better handling car. First thing I did to it was to upgrade the suspension to a set of KW V4 + H&R anti-sway bar kit. Second to that would be some 034 chassis upgrade such as front struct bar + driveshaft tunnel brace(forgot to take some pics of those upgrade). Besides the basic upgrades, I also replace all the control arms' rubber inserts to wishbone inserts to provide a more responsive handling. I also upgraded four control arms to titanium adjustable control arms.
    Back to some exterior mods now, so I pulled the trigger for a set of Maxton kit.
    So I have been always thinking about why Audi decided to delete the fog lights in the B9 generation, I talked to my sales rep and he told me that Audi put the fog lights into the headlights already. However, I am still digging the yellow fog light JDM style look, I removed the front bumper and found out that the ACC sensor section was only a plastic cover for those without the ACC option. After speaking with the shop tech, I decided to order the PIAA yellow fog and hoped that they will fit on the bumper. THANK GOD, I did make them to fit on the front bumper without any issues.
    Feb 14 2006
    Vancouver
    After owning the car for about 6 mons, I felt the rear was still a little bit sloppy after all the handling mods, so I went ahead and ordered more chassis upgrades, 034 Rear subframe mount + rear diff mounts + JXB driveshaft mount. The car felt more solid during cornering after the upgrades. I also felt that the acceleration was more responsive when I stepped on the throttle. However, I didn't feel much of an upgrade on the driveshaft inserts.
    So my Christmas gift arrived early this year, here we come with the new wheels I had ordered 6 mons ago!!!Definitely the nicest wheels and most expensive wheels I have ever owned. Couldn't wait to put those on when I first received them. Wheel specs - 20x9.5 Et8 not the ordinary BBS recommended spec for this car. That's why it took me so long to get them.
    Finally have time to put these bad boys on the car. Really like how it came out with that sporty looking, but I think I still need to do some camber adjustment on the car to make it to perfection.
    After almost 20k kms of mileage, the oem tires started fading out so I decided to replace them with some beefy sport tires which gives better road feedback, better braking and handling. Last not not least, looooooooks wayyyyyyyy better.
    To conclude this thread, I've also include a mod list for the car.
    Engine
    TMC Stage 1 ECU tune
    BMC high flow air filter
    G-Turbo turbo inlet
    Racing cats
    Interior
    P3-Gauge
    Exterior
    Maxton front lip
    Maxton side skirt
    Maxton rear skirt
    Maxton rear diffuser
    Karbel carbon fiber roof spoiler
    Suspension+chassis
    034 Motorsport transmission mount
    034 Motorsport rear diff mount
    034 Motorsport rear sub-frame mount
    034 Motorsport front strut bar
    034 Motorsport driveshaft tunnel brace
    55 Racing control arms kit
    KW V4 coilover
    H&R front + rear anti-sway bars
    Wheels + Tires
    BBS LM with Yokohama AD09 275/30/20
    Established Member Two Rings ILLITE's Avatar
    May 17 2016
    Pennsburg, PA, 18073
    Love it. I thought the same for fogs. Do you have a link or the PIAA part number for the fogs you used?
    21’ S4 Prestige
    Feb 14 2006
    Vancouver
    Quote Originally Posted by ILLITE View Post
    https://www.piaa.co.jp/category/4rin/light/4-lampled/
    model# LP530
    May 17 2016
    Quote Originally Posted by gpxluke View Post
    Thanks! If you don’t mind how easy was the mounting? You’re the first person I’ve seen do this before. I hate all the extra plastic for that ACC cover. I’m pretty handy/DIY from previous builds, but I wasn’t sure if the mounting gave you some trouble or it was relatively straight forward.
    21’ S4 Prestige
    Feb 14 2006
    Vancouver
    i sourced this universal kit to make them fit.
    Veteran Member Three Rings DreamTFK's Avatar
    Nov 01 2019
    Florida
    I always thought those fog light areas were sensors but I don't have ACC. I wanted to do this fog light conversion years ago when I got my S4.
    Hoping the opening is the same size on the US spec S4.
    2020 S4 P+ Quantum Gray BO
    ▪Wagner Competition FMIC w/Charge Pipes
    ▪ECS Carbon ECU Cover | ECS Diverter Valve
    ▪034 Trans Mount | Rear Sway Bar | Springs | 10/12mm Spacers
    ▪034 ECU/TCU Stage 2 93
    ▪Carbnlab Inlet + Airbox Mod/K&N 4" Filter
    ▪CTS Turbo Test Pipe
    May 17 2016
    Quote Originally Posted by DreamTFK View Post
    If you beat me to it please post up your findings. I’ve had the same want for awhile.
    Glad someone finally took this on.
    21’ S4 Prestige
    Sep 28 2010
    NW NC / DE
    My man.... nice work! She looks awesome. Love the LMs with meaty rubber.
    Jan 08 2018
    24 RS5, 24 A6 Allroad
    Twin Cities, MN
    What a thread! I really like everything you've done so far. Well done, Luke!
    Feb 14 2006
    Vancouver
    Thanks! I am still working around with the front and rear camber setting as the rear did rub a bit. I'll post some good quality photoshoot pics when i done working with the alignment adjustment.
    Quote Originally Posted by Diokhan View Post
    Thanks thanks...car is fun to drive with all those upgrades. I was gonna go with a BMW F81 M3 but this thing is priced super high in China, like doubling the price of a b9.5 RS4.
    Feb 14 2006
    Vancouver
    Same size for the S4
    Nov 01 2019
    Florida
    I did a quick measure and it seems to be about 2.5". Is that the size of those lamps?
    Jan 26 2019
    Great thread. Love the Fog lights!
    But I'm interested in the control arms, evem though I have a set of 034. Can you send a link or info on them?
    Feb 14 2006
    Vancouver
    Yes they are the same size...the piaa fog light is about 90mm which is about 3.5 inches the fog light cover will cover the outer brazel and small amount of the fog light but shoudlnt be the problem. its the same size as my rs4 front acc covers
    Feb 14 2006
    Vancouver
    Quote Originally Posted by Esmin23 View Post
    they dont sell online..i got it from a shop that specialized in bmw racing chassis parts. these are order to be made.
    May 22 2023
    MD
    wow a unicorn rs4, looks slick.. is tuning available for this / will this be tracked?
    Feb 14 2006
    Vancouver
    Quote Originally Posted by handspin View Post
    Gonna bring it to track next week ha
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    LOoks good!
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Sep 22 2013
    Man that's beautiful.
    Senior Member Two Rings brandonbanana's Avatar
    Jul 14 2018
    2010 Lexus IS 250, 2023 Audi Q8, 2016 Audi S7
    Oahu, Hawaii
    Phenomenal car! I'd love to do the fog light mod, however, my car has ACC and I love using it in Hawaii traffic
    Feb 14 2006
    Vancouver
    Here are some updates from the track event
    May 22 2023
    MD
    Those are some nice quality wallpaper spec photos! Guessing you have a different set of wheels/tires for the track?
    This is a tuned S4 Wagon, almost RS4 specs on the Nurburgring w/ Mischa:
    https://www.youtube.com/watch?v=BAQvT5Vp4J0
    Feb 14 2006
    Vancouver
    was running a set of 18" Advan GT on the track with slickkkkkk tires lol
    Aug 18 2023
    PA
    That is one great looking Avant!!!
    Really intrigued by the PIAA fog lights...very clever idea!
    Do you mind providing a link to the brackets you used? I searched Ebay, Amazon, etc. with not much luck.
    I'm also curious if you have a switch installed in the car that you use to turn them on/off?
    Would be really slick if somehow you could insert the old fog light button into the "blank" button slot in the image below...seems like a perfect fit.
    Feb 14 2006
    Vancouver
    Quote Originally Posted by zubster89 View Post
    The fog light kit came with a physical switch that I mounted it inside the side cabin at the driver side under the headlight switch unit....I didn't think about wiring it to the light switch unit as I was afraid that I would run into some coding issues...
    Feb 14 2006
    Vancouver
    some updates on the car here...just put a Brembo Pista FF6 BBK with 380mm rotor on the car pairing with a set of Endless CCRG brake pads. Braking power has a significant improve from the Brembo bbk.
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    looks amazing, super jealous, what are you doing with those stock calipers... asking for a friend lol
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Feb 14 2006
    Vancouver
    Quote Originally Posted by richib86 View Post
    Im thinking of selling them
    Nov 05 2006
    Fair Lawn
    i would be interested in them, let me know!
    Aug 11 2021
    Auckland, NZ
    Awesome build mate, well done! Looks sick
    May 24 2023
    Switzerland
    love this build, any news on it
