Results 1 to 3 of 3
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2012 TDI - Cooling Fan Module Code - Fan keeps running
    I have code:*
    4529 - Fan 1 Control Circuit********** P0692 00 [00100111] - Short to Plus
    The fan keeps running (car shut off, locked, etc) for a long time (this is NOT the 'afterrun cooling' when engine is very hot).
    I assum faulty fan control module.*
    Can someone provide me with the part number (tough to get to the module inbedded into the back of the fan)?
    Is the TDI maybe using the same as the gas 3.0? Plenty of those around:
    https://i.ebayimg.com/images/g/obAAA...h~/s-l1600.jpg
    I would try one from junkyard,and avoid having to take the whole fan assembly/carrier out (may even need front bumper off?)
    Maybe someone even has a link to DIY change of the module?*
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    FAN1=Right=Large fan
    Don't see module for FAN1, only for the small (right) fan.
    Top of fan 2 has cast in 'box', maybe module is in there. Does NOT look like this (module of large fan 1, top of fan):
    https://i.ebayimg.com/images/g/ObcAA...P3/s-l1600.jpg
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Looks more like this https://i.ebayimg.com/images/g/tQkAA...Ny/s-l1600.jpg
    Does someone know if the MODULE is hidden inside the plastic molded 'box' on top since only one (for the small fan) is visible?
    05 Golf TDI
