Results 1 to 14 of 14
    Senior Member Two Rings Nsd991's Avatar
    Nov 29 2016
    Texas
    2021 RS6 Air Suspension failure
    2021 RS6 no suspension mods, 13500 miles. If I leave the car parked for more than 2 days the front air suspension collapses and the car is slammed. I’ve been to dealer with this issue and the found no fault. If I drive the car it resumes normal height and the car suspension settings work normally. Any ideas or similar experiences? Somehow the attached photo is rotated and the top of the wheel well is to the left.
    2023 SQ8 Daytona Carbon Optics
    2021 RS6 Avant Sebring Black
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Does the virtual cockpit give you a "Suspension too low. Please wait" style message when starting up in this condition? I received a message indicating as such once after my car sat for over a week when temps spanned from 30s to 0/sub-zeroF. The suspension adjusted and the message cleared after 10-15 seconds or so. I would think if you are not receiving a message of some kind, there is some ride-height calibration problem.
    Nov 29 2016
    Texas
    Quote Originally Posted by FBAnder View Post
    Yes I get that message. But still I’m assuming something is wrong because the car is absolutely slammed???
    Mar 05 2020
    Chicago Metro
    Quote Originally Posted by Nsd991 View Post
    Mine didn't look as low as the image you shared when I got the message. If there is a small leak in the system that is going to increase the wear on the pump. I can't think of any air suspension setup being "normal" looking slammed after a couple days of non-usage. I've let mine sit for a couple weeks with no discernable suspension drop.
    Sounds like standard dealer "within spec" stuff. Gonna have to push or maybe try another dealer.
    Nov 29 2016
    Texas
    I think you are correct, before it would take a week of inactivity, now just a day or two. Even if they don’t fix I want it noted so when out of warranty it’s not all of a sudden a $$$$ fix. Thanks for your input. Taking it tomorrow and will update here
    Nov 29 2016
    Texas
    No fault in system found but at least it’s noted should it become an issue
    Junior Member Two Rings wheeljouster's Avatar
    Mar 09 2021
    Washington
    Any update on your issue?
    Last summer, my 21 S6 would drop if left for a few weeks, which is eh, understandable.
    Now it’s dropping the driver front only and after just 1 day it’s bottomed out. Obviously there’s a leak and/or damage to that area. It gives me a fault upon startup, but then clears after it airs back up.
    2021 S6 Prestige
    2022 S5 Coupe Prestige
    2016 & 2009 Yamaha YZF-R1
    IG @wheeljouster
    Nov 29 2016
    Texas
    Quote Originally Posted by wheeljouster View Post
    Dealer said they didn’t find a leak BUT the issue is documented so in the future should not be a problem if not under warranty. I drive the car daily son has not been sitting for more than a day so not dropping for now
    - - - Updated - - -
    Keep me posted if they find an issue with your car
    Mar 09 2021
    Washington
    - - - Updated - - -
    Will do. I'm taking it in tomorrow for the 4 recalls and hopefully they'll find the leak.
    2021 S6 Prestige
    IG @wheeljouster
    Mar 09 2021
    Washington
    The dealer found a leak in the driver's front air strut. They are currently waiting for parts to arrive.
    2021 S6 Prestige
    IG @wheeljouster
    Nov 29 2016
    Texas
    Good for you, keep us posted. I may have to drive to Washington
    Mar 09 2021
    Washington
    Forgot to update. My car finished up on 4/19 and it's perfect. Audi Seattle did a good job.
    2021 S6 Prestige
    IG @wheeljouster
    Established Member Two Rings allenyao09's Avatar
    Aug 18 2021
    21' Audi RS6 Avant, 23' Toyota Supra 3.0 MT, 08' Mitsubishi Evo X GSR
    I found my 21 RS6 dropped its suspension after being parked for 3 days. Will have the dealer check it out when I do the next service.
    2024 Lotus Emira FE 3.5 MT Atlantis Blue
    2023 Toyota GR Supra 3.0 MT Nitro Yellow (gone)
    2021 Audi RS6 Avant Glacier White
    2008 Mitsubishi Lancer Evo X GSR Octane Blue (gone)
    Nov 29 2016
    Texas
    Quote Originally Posted by allenyao09 View Post
    Keep us posted, Minei’s getting progressively worse
