Hi guys, I’m fairly new here and wanted to get some opinions. I recently purchased an 03 a4 1.8 TIP Quattro with a blown motor. I replaced the motor with a used 1.8 with 130k miles on it and it runs well. While in process I made a few trips to the local junkyard for odds and ends and found the 5 speed version of my car but loaded with a bunch of goodies. So far I’ve pulled a F21L Frankenturbo with the billet compressor upgrade, boost brothers FMIC, 550cc Bosch injectors, 034 silicone turbo inlet hose, a billet diverter valve and what I assume is a remapped/tuned ECU(it’s been opened, has blue paint pen on the 4 Torx bolts securing the cover and SG2 in the same pen written on the bottom. I got an 034 poly snubber, 3” MAF, 3” catless down pipe as well as a few other things. Now I’m not sure how to proceed.
This is my 1st Audi and my 1st turbo car in quite a long time. Stock, it’s a little underwhelming and I’d like some more power out of it, but not sure how to proceed as I’ve got no idea what kind of tune the donor car is actually running. I don’t want to add all these goodies only to have the car make 300+ hp and break a rod or a ring land.
Would it be safe to install the turbo and fmic on the stock ecu? Or maybe just the diverter and fmic? I’ve been using the free version of VCDS to get acquainted with it and intend on upgrading to the paid version shortly for more usability.
Any thoughts/suggestions/recommendations would be much appreciated.
I plan on going back to see if the donor has an aftermarket fuel pump/ pressure regulator. I can’t imagine the fuel system is stock with all the other add-ons the car had.
