With 22 years and 165K miles on my car's original pump, I'm thinking I should preventatively replace it. Looking at the available pumps, it would seem the only thing offered is the complete module assembly unless going with a bigger volume pump. But can't you replace JUST the pump? I messed around with a B7 pump module in the junkyard the other day and was able to remove just the pump with a little creatively. Is that not possible with the B6 module?
