"stock" 034 flash. Throws a bunch of module codes even though battery is fresh and voltage looks low. Maybe grounding/B+ connections are awry? where would those be under the hood?
Tuesday,02,January,2024,21:45:44:01176
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WAUMGBFL5AA105927 License Plate:
Mileage: 167210km-103899mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 36 3C 3E 42 46 47 52 53 55 56
5F 62 6C 72
VIN: WAUMGBFL5AA105927 Mileage: 167210km-103899miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
3E-Media Player 4 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H06 0003
Revision: --H06--- CVN: BC966676
Coding: 0104000A180F0128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 323D168464AF281AE97-8066
VINID: 9D195D5D259C1514410052421CD2EB98FF
4 Faults Found:
6516 - Throttle Valve Controller
P1545 00 [10100101] - Malfunction
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 167210 km
Date: 2024.01.01
Time: 22:28:07
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 98 °C
Intake air temperature: 47 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.187 V
Unlearning counter according OBD: 40
Engine speed: actual: 0 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 98.3 °C
Engine: operating status: ES
Engine load: 0.000000 %
Vehicle speed: actual: 0 km/h
9831 - Intake Air Regulating Flap
P10A4 00 [00100100] - Mechanical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 167210 km
Date: 2024.01.01
Time: 22:28:06
PDT_ENVD: 981.72852 hPa
RFP_SP_ENVD: 76.8898
RFP_AV_ENVD: 0.0000
VP_RFP_1_ENVD: 0.07813 V
RFPPWM_ENVD: 0.00000 %
7804 - Position Sensor for Intake Air Regulating Flap
P10A6 00 [10100101] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 167210 km
Date: 2024.01.01
Time: 22:28:06
V_PVS_1_ENVD: 0.74219 V
RFP_SP_ENVD: 0.0000
7814 - Coolant Pump for Intercooler
P190C 00 [00100100] - No Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 167210 km
Date: 2024.01.01
Time: 22:28:12
Intake air temperature: 48 °C
Readiness: 1110 1101
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Revision: -------- Serial number: --------------
Coding: 280D18
VCID: 7AADFEA4FCDF105A617-802E
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 0F0100
VCID: 78A9E4ACC2D3024A173-802C
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000098730006
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01081220091769
Coding: 66102000
VCID: 00598C4C9A034A8A2F3-8054
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000533828
Coding: 26001091063CAF010000080300003D0D0F1C12080001016100 0000
VCID: 3C2138BCB66BEE6A33B-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 081209 H06 0070
Serial number: SWF09120085708
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10706270
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000003011091353
1 Fault Found:
02258 - Door Opener Transmitter
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 56
Mileage: 167210 km
Time Indication: 0
Date: 2024.01.01
Time: 22:28:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940934305034
Coding: 20000D
VCID: 3E2532B4A077FC7A1DF-806A
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD05C80S Dataset Number: 8K0909602H 0005
Coding: 303936354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 42DD4644D40F989A797-8016
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R09000057ZJ
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4E632710A
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME4E342F3CV
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME084637229
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME06463D16H
Crash sensor for front airbag: driver side:
Serial number: 63732SME42463F280
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME4346230AW
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319ILA000K3
Coding: 000016
VCID: 3D2735B8AD71E762045-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 Q HW: 8K0 920 980 Q
Component: KOMBIINSTR. H05 0255
Revision: 00100000 Serial number: CJ241LYC9
Coding: 8B1D09000300D705020000
VCID: 40D94C4CDA838A8A6F3-8014
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0105
Revision: FB900055 Serial number: 5500F09B2780A4
Coding: 00C303
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1909E63E301109
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010045032
Coding: 00581B00000000000000
VCID: 3B233BA0B365E9523A1-806E
Address 3C: Lane Change Labels: None
Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0030
Revision: 00H01000 Serial number: 6PZ 009 014-82
Coding: 0000001
VCID: 3C2138BCBA6BEE6A33B-8068
Subsystem 1 - Part No: 8K0 907 568 H
Component: J0770_SWA_Slave_H01 0030
Subsystem 2 - Serial number: 6PZ 009 014-92
Subsystem 3 - Serial number: 5F05.12.0900H010003C321180ÿ
Subsystem 4 - Serial number: 321180ÿ
Address 3E: Media Player 4
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009740561
Coding: 011C13204E00410001
VCID: 45D75D58C5A1AFA25C5-8010
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0124212742
Coding: 0106023A007A444500B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000198323
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882000738801
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009769163
VCID: 44D1405CCE9B96AA4BB-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000520634
Shop #: WSC 00000 000 00000
VCID: 3431109C9E3B262AFBB-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 77ABE790C3CD0D321E9-8022
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335L+097543690
Coding: 020000010000000001
VCID: 1D67D5380DB18762245-8048
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 F HW: 8T1 035 664 B
Component: H-BN-NA H47 0189
Revision: -------- Serial number: 490CR0A7551602
Coding: 010200000206A1EF51000F0E000000030000
Shop #: WSC 34413 001 1048576
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356LV091151724
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000422851
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102492704
Coding: 010C13204000210001
VCID: 42DD4644D48F989A797-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J9Y91A3
Coding: 1000006
VCID: 382924AC8E53C24AD73-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102492726
End----------(Elapsed Time: 01:44, VBatt start/end: 12.3V/12.3V)-----------
