Results 1 to 12 of 12
    Nov 27 2011
    Annapolis, MD
    Changing rear brakes - OBDeleven to retract EPB - not working
    OK, super frustrating.....
    2015 S4.
    Reviewing Audi and VW board posts, Youtube videos & OBDeleven info for OBDeleven steps for retracting electric parking brake in order to replace rear pads and rotors. It appears all info is there to perform the task.
    Purchase OBDeleven from ECStuning, register acct and connect to phone with it in S4. Can scans for codes (none), and walk thru all menus and features of ODBeleven. Go to EPB menu. I see the different functions listed (all good).
    Go to Basic Settings.
    with car running (or not), toggle EPB to release, then re-engage.
    Then go to Basic Functions and select:
    - Start Line Change
    > Observe: (22) - Function Cancelled, marginal conditions have not been met
    I pop open the hood
    Connect battery charger (per some VW instructions...)
    Same thing.
    After 3+ weeks of trying to get OBDeleven support to reply, I finally get response that I need to purchase credits for the "one touch App" features to work ?!?!?
    No info on how many or how much ??
    Does this sound right ??
    ECStuning said it was good to go out of the box for this feature.
    Help !!
    thanks in advance.....
    2015 S4 - Nogaro - Panda – 6MT
    2014 Allroad
    2012 Honda Ridgeline
    Formers:
    2015 A4 – 6MT
    2008 A4 Avant - 6MT
    1985 GT Coupe - 5MT
    1982 GT Coupe - 5MT
    Jul 16 2018
    Atlanta
    The EPB in the B8.0 is a CAN protocol control module, and the basic settings are invoked by a channel number. 007 to release the EPB, 006 to resecure the EPB.
    The EPB in the B8.5 is a UDS protocol control module, and the basic settings are invoked by action names, in a drop list. Same results, just different access process.
    In either case, the actions are "basic settings". Same doing the headlamp level basic setting. Basic settings are not accessible in OBDeleven unless you have the PRO subscription. Same for "long coding" and "adaptations" (the battery change task, e.g., is to update an adaptation value).
    Did you get the PRO purchase, or just the device? If you don't have direct access to "PRO" functions, you can indirectly access them with OBDeleven's one button apps. Which cost credits. Which you have to buy. There's not even a one button app for doing the battery change, not sure about the headlamp level basic setting.
    All of this is the same as it's always been with OBDeleven, except that the PRO license long ago was a one time $30 purchase, and now it is a $54 annual subscription. 5 credits is basically a dollar.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Exact silly reasons why I always suggest people just buy VagCom if they’re going to own a VW group car and do work on it. None of this silly ass credit shit and you can use it on all your friends cars too to help them. And it’s also far superior in its scanning and coding capabilities.
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    Regarding retracting the pistons, I find it a whole lot easier just to just take off the motors and retract them manually, no need for VagCom or OBDeleven
    Simply unbolt the motor from the back of the caliper (2 X Torx ).
    Then there is a Torx in the centre to wind back the screw.
    Then squeeze bacK the piston using the old pad as normal (no screwing)
    Plenty of info on the internet, example here..... https://www.youtube.com/watch?v=34G3qDPNldE
    Jul 16 2018
    Atlanta
    "I find it a whole lot easier"
    Nov 27 2011
    Annapolis, MD
    thanks for replies everyone...
    I purchased OBDeleven - Pro. Yes, I have the pull down menu under Basic Settings shoing: Start Line Change (retract) and EndLine Change (close). But, these don't work. I get the (22) message.
    Do I need to buy credits with Pro ??
    thanks again.
    2014 Allroad
    Formers:
    2015 A4 – 6MT
    2008 A4 Avant - 6MT
    1985 GT Coupe - 5MT
    1982 GT Coupe - 5MT
    Jul 16 2018
    Atlanta
    If you have Pro, you do not need to do anything with credits. You have direct access to the basic setting action.
    What is your battery voltage? This has come up before with the B8.5 UDS EPB module, I feel. I think they had low battery voltage so the car was not permitting the action. The proper process is to hook up a battery charger anyway for the duration of the rear brake change.
    Also, I assume the EPB is released? You can't do this with the EPB engaged. The process I recall, as I don't use EPB hardly ever, is ignition on, engage EPB, release EPB, perform basic setting to retract EPB.
    Aug 05 2013
    N/A
    Make sure your engine isn’t running when you try to do this. It only requires ignition On, so key in and press once without foot on brake or press Start button once without foot on brake. Same for when you close them back up after you change out the pads and remount everything. Don’t start the engine. Once closed, then you can start it.
    Nov 27 2011
    Annapolis, MD
    thanks again for replies.
    Conflicting info in these relies wrt ignition on or off.
    Here is what I have tried:
    I have OBDeleven Pro.
    Engine running and off (both ways...).
    battery charger on ( for 20-25 mins - in case battery voltage was low). and off. Charger ON is NOT listed as step on OBDeleven process. I do see it listed on VW forum steps, BUT is this voltage measurement truly a step and has to be > xx volts, or is this just a recommended step ??
    Hood open
    Level ground
    EPB ON (I haven't tried it with it off yet). Though instructions from OBDeleven and VW forums all state: ( engage EPB, disengage, re-engage, then retract via OBDeleven command).
    thanks again !
    2014 Allroad
    Formers:
    2015 A4 – 6MT
    2008 A4 Avant - 6MT
    1985 GT Coupe - 5MT
    1982 GT Coupe - 5MT
    Aug 05 2013
    N/A
    OMFG!!! Turn the parking brake off man! Jesus! How do you expect it to back off the brake calipers with EPB On?! Listen, it’s pretty simple. Turn ignition On WITHOUT engine running. You can’t talk to the modules without them being powered up and this is the only way they’ll have power. Make sure your parking brake is OFF. Then issue the command to back off the rear calipers for service. Then turn the ignition Off and work on the car. DO NOT issue command to put rear brakes back into normal until everything is back together again, NO EXCEPTIONS.
    If your car is DSG and it’s in Park, you’re fine, it won’t roll on you. If you’re manual, put the shit in first if you’re worried about it rolling. There’s no reason to have the parking brake On when doing this because that’s the whole point behind this procedure… it back off the screw that IS the parking brake so that you can compress the calipers back to make room for the new pads.
    Aug 05 2013
    N/A
    Quote Originally Posted by audi-puck View Post
    I dunno where you got these instructions from, but they’re wrong. I seriously doubt it’s like this on other VW’s, it would be impossible for the car to retract the EPB with it engaged. I see it as a safety issue and the module simply will not respond to the request as it doesn’t know if the car will roll or not or whatever. With EPB disengaged, the module is free to back off the screw since the back caliper isn’t clamping down for any reason, so it presumes it’s safe to do so.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by SwankPeRFection View Post
    Definitely sound like OP has the instructions backward, where they tell you to "Cycle the EPB on and then OFF" before starting the procedure, and not the other way around.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
