Results 1 to 26 of 26
    Junior Member One Ring
    Aug 08 2023
    Carlsbad, CA
    Aftermarket TPMS?
    Has anyone added an aftermarket TPMS? I see there are lots of inexpensive options that use bluetooth and can be read on your phone. The easy ones are built into a new valve core (screws into the valve stem). Just looking for something that others have found to be good. Not afraid to pay a bit more for quality. But I don't really want to have somthing that will require special attention from the tire installer or have to replace the valve stem.
    I've had 2 tire issues in the last few months with my Q5 and both times I wished I had a real TPMS which reads tire pressure.
    First I got a rock through a sidewall on a gravel road in the Sierra's on the way to the trailhead for a hike. I got a "Total loss of pressure" alarm. I stopped immediately, got out, and saw that I had been driving on an uninflated tire for some time. Fortunately I didn't damage the rim. So no harm no foul but the delay in the alarm coming in reduced my confidence in the system. Then I had to drive 300 miles home on the spare and it would have been great to have been able to monitor the air pressure.
    So, since I need more rugged performance from my tires, I put a set of 18" wheels and some very durable tires on and have been very happy. Still not totally trusting of the system to give me prompt alarms. So last week I was 300 miles from home again when I got a low pressure alarm. Checked pressure and it was 15 psi low. I was disappointed that it was that low before I got the alarm. I looked for a nail, couldn't find one, aired the tire up and drove home. Got home and it was just a couple of pounds low. but I thought about it the entire way because I couldn't monitor the pressure, just wait for the alarm. Next day I got up and it was a couple of pounds lower. took the tire off, found a nail, and repaired it.
    So I'd like to have an easy way to monitor tire pressure, like I have on my cheap Nissan that my son drives.
    Jerry
    2021 Audi Q5 Prestige Blue
    19" summer wheels
    18" Offroad wheels
    ECS skid plate
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Why go aftermarket when you can retrofit the OE direct TPMS system for like $150?
    iain
    Oct 29 2021
    Lancaster, PA USA
    Because the OE tpms can't report pressures. I've wondered this many times. Not sure why Audi is trying to save a couple bucks here. Just do it right like every other manufacturer out there.
    Jul 16 2018
    Atlanta
    The indirect system does not read tire pressures. The direct system does. As for enabling the display of the individual pressures in the instrument cluster, not sure how simple that is. But look at the direct TPMS retrofit thread in the B9 A4, B9 S4, or B9 A5/S5 forum, whichever one it is in. $150 might be optimistic though, to get a J502, the four sensors, the four sensors installed, the wiring, etc.
    Aug 08 2023
    Carlsbad, CA
    Thanks guys. I didn't realize audi offered a direct reading TPMS. I'll look into it. --Jerry
    19" summer wheels
    18" Offroad wheels
    ECS skid plate
    Aug 08 2023
    Carlsbad, CA
    Ok. I have found the retrofit kit for B9 A4/S4/A5/S5/RS5 sold by Euro Zone Tuning. I remember my friend with a TT says that he has real TPMS. So some models have it and good chance the Q5 CPU supports it. I've sent EZT a note asking if they know if it is available or adaptable to the Q5.
    thanks.
    19" summer wheels
    18" Offroad wheels
    ECS skid plate
    Apr 08 2011
    NoVA
    Aftermarket TPMS?
    Quote Originally Posted by Mark888 View Post
    Yes it can. That’s the point of retrofitting the direct OE system. It’s from the RS cars.
    It’s cheap and fairly simple to do.
    Quote Originally Posted by Gunnarrrrr View Post
    got my rs5 tpms kit
    Attachment 319750
    iain
    May 17 2022
    1991 Eagle Talon TSi AWD
    GA
    Current ECUs still support active TPMS. You just need to wire in the sensor to the secondary CAN bus and then code the ECU to disable passive TPMS and look for the controller to enable active TPMS. Did this to my '23 SQ5.
    https://www.audizine.com/forum/showt...1#post14962683
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    As mentioned above, you can get the RS5 retrofit kit for cheap. I grabbed the full set in that pic for $100 shipped with a black friday deal. Just need to remove the rear seat bench and mount the antenna there and run a couple wires, or have a shop do it if you don’t want to. The more tech-heavy forums like audi-sport have lots of write ups. It’s as easy as changing a value in vcds/obdeleven and it’s enabled.
    https://www.audizine.com/forum/showt...PMS-to-your-B9
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Established Member Two Rings unluky's Avatar
    Apr 29 2023
    2015 BMW X5 35i / 2004 BMW Z4 3.0 Sport
    Sedalia, MO
    Thank you for this - I've been looking for more Audi forums - specifically ones more "hands on" and this seems right up my alley!
    Mar 25 2015
    Placer County
    Quote Originally Posted by unluky View Post
    Audizine for the mechanical stuff, audi-sport for the nerdy electronics stuff and retrofits. Those are the only two I use anymore.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 10 2021
    MA
    I keep going back and forth on doing this.
    I mean on one hand I have a tire gauge and can check em any time I want - but on the other hand I had this on my Cadillac CTS-V and I loved being able to see when my tires had warmed up (usually right before I got on my favorite on ramp and threw it around the decreasing radius corner at straight to jail speeds).
    On one hand its cool, on the other hand its totally not necessary.
    save for retirement? more cool unnecessary shit for my car? buy more stuff for the house?
    2022 SQ5
    CTS Intercooler, Downpipe
    Jackal / M2 Full custom ECU and TCU
    Diamond Audio Subwoofer + 20'' LightBar
    Custom PCV system + Mishimoto catch can
    ABT HAS, ECS Skid Plate, Roc Euro Intake, DashCam
    034 Trans Insert, Turbo inlet, Sway Bars, Strut Brace, HPFP
    Chrome Delete + CF Mirror Caps / Wide Angle Mirrors, Mud flaps
    Oct 29 2021
    Lancaster, PA USA
    Quote Originally Posted by Local View Post
    I thought about this briefly but decided to move on to something else that is less work and or more reward. Curious if the next gen audis will have it? What about Porsche SUVs?
    Apr 08 2011
    NoVA
    Audi was supposed to add the direct TPMS system to the B9.5 cars but then COVID happened and they pulled the plug on it due to the microchip shortage. I imagine they still haven’t followed through with it because they’re pinching pennies.
    iain
    Jul 16 2018
    Atlanta
    AoA added direct TPMS as standard to all A/S 6/7 and Q/SQ 7/8 vehicles starting MY22. That of course requires Audi to have the option available on the applicable model. There's no reference to the control module or the wheel sensors in the B9 parts catalogs, except the RS4 and RS5 ones.
    Audi wasn't about to incur that kind of cost for no reason. The direct to indirect change across the product lines for MY10 saved money and let them market no cost of ownership tpms. Even with things like https://www.consumerreports.org/cars...m-a6644749463/ , the cost of all that hardware across the product lines would be much more expensive. Maybe AoA was starting to get too much flak for why modern Audis still couldn't do something baseline GMs had been doing for over a decade.
    Maybe it was too much volume for the parts availability, or maybe there was no intention of doing it in the lower cost B segment. Who knows. Will we see it standard when B10 comes? Who knows.
    Apr 08 2011
    NoVA
    Aftermarket TPMS?
    Yea I mis-remembered, it was supposed to start in MY22 and all C and D segment cars.
    D segment is the A4/5 Q5 cars. C segment is the A3.
    iain
    Jul 16 2018
    Atlanta
    They delivered on that. D segment is the A8, thus why it's generations are referred to as D3, D4, D5. C segment is the A6, now also the A7 (current gen is C8). B segment is the A4, now also the A5 and the Q5 (e.g, the B9 Q5 aka the Mk2 Q5 aka the type FY). Q7 is kind of it's own thing, but no one decided to refer to it as E1 (type 4L Q7) and E2 (type 4M Q7 and Q8).
    Jun 21 2021
    Naperville, IL
    Thank you for the info above, i ended up buying the tpms kit. However, I don't trust my skill set to tear the car apart. What kind of shop should I go to have it installed?
    Apr 08 2011
    NoVA
    Quote Originally Posted by Smac770 View Post
    You’re confusing Audi’s internal chassis codes with the industry term “segment” which is an ISO 3833-1977 classification for vehicle types/sizes.
    D-segment cars are mid-size sedans in the US. The A8 is not a mid-size sedan. The A4 is.
    A3 is C-segment
    A4 is D-segment
    A6 is E-segment
    A8 is F-segment
    iain
    Jul 16 2018
    Atlanta
    A3 is C-segment
    A4 is D-segment
    A6 is E-segment
    A8 is F-segment
    If you're using that classification system. Whoever wrote the Audi document is clearly using their own platform designations, not some ISO document designations. They were not adding direct TPMS to the A4/A5 (the B vehicles). They were adding, and did add, direct TPMS to the A6/A7/A8 (the C and D vehicles).
    Mar 25 2015
    Placer County
    Quote Originally Posted by terrspin11 View Post
    I'll have a detailed write-up in a couple days. believe it or not, no tearing the car apart was necessary whatsoever. anything I needed to access was accessible by the removable cubby in the back, and lifting the rear seat bench. 100% plug and play, I honestly didn't even need my wiring pin tools.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jun 21 2021
    Naperville, IL
    Oh, wow, great! The video i saw above seemed to tear the car apart, so glad to hear I don't! And I have the obd11 to get it coded. thank you!
    Mar 25 2015
    Placer County
    some people opted to grab power and can+- from the front of the car, which is a total waste of time. After staring at the wiring diagrams in the service manual until I went crosseyed, I determined that can hi and lo from the comfort module under the rear seat is the way to go, and the fuse panel in the back has the C6 location empty for all q/sq5’s.
    That is the exact same fuse location listed for the b9 a/s/rs 4/5 as power for the rear pdc. for the RS, it powers the pdc and the tpms (which is mounted above the rear subframe in the RS). So IF audi were to have offered tpms with the Q, this is where they would have put it to be consistent with the other b9’s. It’s already powered, all that’s needed is to plug the wire from the antenna harness into the back of it, and throw in a 5A fuse.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Oct 29 2021
    Lancaster, PA USA
    Stoked to read this once posted.
    Mar 10 2021
    MA
    If its really this easy maybe I'll just order the parts ... you know to be safe.
    2022 SQ5
    Mar 25 2015
    Placer County
    let me get my sensors installed and make sure it works before i give u my link, I paid 108 shipped in black friday, think it’s like $135 now.
    I’ve got the DIY typed out in a text file just need to take more pics and test it after coding
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
