Results 1 to 15 of 15
    Junior Member Two Rings Sla's Avatar
    Nov 22 2023
    odessa ukraine
    Carbon ceramic brake pads AUDI RS7 Performance 2016
    Hello everyone, according to the catalog front pads 4H0698151C (4H0698151P), rear pads 4H0698451F (4H0698451P)
    What non-original brands of pads do you use? if possible the part number?
    the front ones I chose Brembo P85175N but I’m not sure that they will fit a ceramic disc..
    the rear ones are HAWK HB915B.664, but on the official HAWK website they answered that they do not fit a ceramic disc..
    What do you use? please share your experience
    PS maybe this topic was on the forum, sorry, I’m using a translator, it’s difficult for me to search
    Sep 22 2023
    Massachusetts
    How many miles on your pads ? I have 30k miles on my 16 rs7 performance and still have plenty of pad left
    Nov 22 2023
    odessa ukraine
    at the moment 80 thousand km, about 55 thousand miles, the wear is not critical, I want to order something to keep just in case
    Sep 22 2023
    Massachusetts
    I would go stock replacement, that's what I'm going to go with when its time to replace
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Sla View Post
    The Brembo USA website says that P85175N will fit 2016 RS7 Performance. If you need to use OEM for rear, a number of Audi dealers will discount parts about 20-25% off retail, for example Audi Nyack (New York).
    There seems to be little discussion of ceramic discs for RS7 Performance on AZ, probably due to cost that few AZ members can afford, except possibly Nosferatu, IowaRS7, and THCarpenter!
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Senior Member Two Rings jeff351's Avatar
    Dec 16 2020
    2015 Q5 Prestige TDI, 2016 RS7 Performance
    oklahoma
    I just had mine at the dealership for some tires and they measured my pads at 9mm and my car has 75k miles on it, from looking online new pads are 17-18mm
    Nov 22 2023
    odessa ukraine
    Quote Originally Posted by Alabama View Post
    thank you very much, I don’t want to install OEM, the price is unreasonably high, I understand that the car is not cheap either, I’ll look for a Brembo for a ceramic disc, if there is a number for the rear Brembo, please give me, or a link to Brembo USA
    www.brembostoreusa.com
    yes, this site gives the front ones P85175N, but not the rear ones :(
    Hello,
    Thank you for contacting us. Unfortunately, we do not stock the correct rear pads for your RS7. Only front pads are available:
    https://www.brembostoreusa.com/produ...ad-set/P85175N
    Thank you for choosing BrembostoreUSA.com!
    I’m still looking for alternatives to OEM rear pads, share your experience
    Nov 22 2023
    odessa ukraine
    correct Brembo rear pad number P85151N
    Jan 19 2024
    West Milford New Jersey U.S.A.
    In my experience, not many pads top the OME pads. I would think that rings true for the ceramic.
    I also have the ceramic brakes and I will be going with the factory.
    The car stops on a dime now so I can’t imagine it getting much better.
    Established Member Two Rings caelric's Avatar
    Jun 10 2023
    Colorado Springs, CO
    bit late, but did you ever find a good source for front and/or rear pad that aren't $1,000 USD? the brembo pads listed for the front show out of stock
    2016 RS7 Performance - Prism Silver Crystal - Comfort/Bang & Olufsen - DS1 Stage Custom 1 w/ BTRes- TGK Intake - 034 Suspension/Transmission/Differential Inserts
    Dec 16 2020
    oklahoma
    Quote Originally Posted by caelric View Post
    I just found the brembos on ebay for $100, says they are in stock so we'll see in a couple of days if they show up
    Jun 10 2023
    Quote Originally Posted by jeff351 View Post
    will be interested to see the results
    Nov 22 2023
    odessa ukraine
    I also bought it on ebey, I need to look for it
    Dec 16 2020
    oklahoma
    The pads came in and look great however the calipers do not have the open top and require a special socket to remove that i was not aware of and have yet to complete the job
