Originally Posted by
badger.
I'm *this* close to getting into a Uni Stg3 '19 RS3.
Does NOT have a built motor but has all other supporting mods (Uni/Iroz brands). I've been combing through a ton of forums and past threads, but many stalled out in the 2019-2020 range.
I've seen one example directly mentioned of motor failure on E85 Stg3 with TTE700 at 7500k miles, and saw some references to maybe some others but no specifics...
I guess, now that it is almost 2024, what is the consensus on running Stg3 TTE700 on a stock block? Safe, or Stupid? Would be a DD.
And all other factors aside, is Stg3 93 map safer for DD than Stg3 E85 map? (understand power would be down)
Thanks
17' bought it with 3k miles now 30k miles stg1+ to stg3 tte700 sb for the last 6 months and 6000 miles uni tunes.
No issues, change oil every 5k, check plugs and plug gaps every 5k.
I DD mine 60 miles a day. Winter time is 93oct, summer time is E-60/65.
I also don't beat the piss out of it everyday but yet again can on a weekend.
Biggest thing I've learned from forums and FB for a sb is if you're roll racing be above 4k rmps always.
Most tuners have kept the torque capped to not window your block but yet again it can happen.
The 700 is a great turbo for this car and boost is about 300-400 rmps later than a stg2 e85 car.
You'll love the turbo whistle and pull all the way to redline.
