Results 1 to 18 of 18
    Mar 07 2023
    massachusetts
    2017 Audi A6 3.0T - Diff & Transfer Case Oil Change
    I have decided to change differential oil and I was wondering which part (rear diff or transfer case) shares the same oil as the transmission? I only know that that’s the case of 6MT, but not for 8AT (ZF8HP).
    I bought the LiquiMoly 75w-90 gl4/5 (1qt) for the rear diff, but which oil do the front diff and case use? Is it the same one?
    Thanks for future help.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Any GL5 synthetic will work. On my 3.0 I went with Valvoline
    Mar 07 2023
    massachusetts
    I bought LiquidMoly 75w90 GL5 Only, not the GL4+ (GL4/GL5) and the shop told me to get GL4+ because that’s what popped up in their system as OEM equivalent. Shall I return these and get GL4+?
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Never heard of GL4+ and doesn't look like it has SAE designation (https://bobistheoilguy.com/forums/th...6/#post-729255)
    I've done GL4/GL5 75W-90 in my front, center, and rear. ZF, who makes the center diff/transfer case, says the $100/L Audi gear oil w/ Sturaco (G-055-145-A2) isn't necessary unless you install a brand-new center diff. If I can find the ZF published PDF I read before about this I'll link it here. Basically, just get 3L of 75W-90 and you're good.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Sep 12 2022
    Syracuse, NY
    So how do you replace the center diff fluid? I bought erwin for a day and trying to find the procedure for doing the center diff / transfer case
    Sent from my SM-G998U using Tapatalk
    Established Member Two Rings cuerna's Avatar
    Jun 23 2010
    Lubbock, Texas
    I bought Ravenol awd-torsen for center diferrential ($75) and redline 75W-90 for rear and front.
    Audi A6 2012 3.0T
    BMW 330i 2006
    VW GLI MKV 2.0T
    Audi A4 B6 1.8T
    VW Golf MK4 2.0
    VW beetle 1995
    Jun 23 2010
    Lubbock, Texas
    Quote Originally Posted by will.k.315 View Post
    Audi A6 2012 3.0T
    BMW 330i 2006
    VW GLI MKV 2.0T
    Audi A4 B6 1.8T
    VW Golf MK4 2.0
    VW beetle 1995
    Sep 12 2022
    Syracuse, NY
    Quote Originally Posted by cuerna View Post
    Is that under maintenance or repair procedures?
    Nov 27 2018
    Valparaiso, IN
    This video is for the center diff (transfer case) on a 2012 A8 4.2 but its basically the same.
    https://www.youtube.com/watch?v=oz3gftOh9mA
    ALWAYS make sure to loosen the fill plug first. You want to know you can refill it BEFORE you drain it.
    Junior Member Two Rings
    Aug 03 2021
    Kansas
    2014 A6 3.0T APR Stage I, IE Intake, CTS Downpipes, Magnaflow Cat-back
    Sep 12 2022
    Syracuse, NY
    That's just the front diff though isn't it? Where is the center diff?
    Nov 27 2018
    Valparaiso, IN
    See my video. Ass end of the transmission.
    Sep 12 2022
    Syracuse, NY
    Quote Originally Posted by Valpo A7 View Post
    Oh I thought that was the fill and drain for the transmission itself
    Aug 03 2021
    Kansas
    Sorry, there are a number of links in that thread that are helpful. This should be really helpful:
    New DIY Videos!!
    1. Rear Differential Gear Oil video:https://youtu.be/RLyTP5qIRQk
    2. Front Differential Gear Oil video:https://youtu.be/xwD-gGGTyfE
    3. Transmission fluid and Center Transfer Case oil video:https://youtu.be/IY_VRHlfJuQ
    Nov 27 2018
    Valparaiso, IN
    No, the transmission fluid change is much more involved than 2 plugs. To do the trans right you have to drop the whole pan and change the filter as well. When you refill it then you need a way to monitor the transmission fluid temp and be in a certain window to fill it up to the correct level.
    Active Member One Ring DanTheC7Man's Avatar
    Nov 16 2023
    Charlotte, NC
    Quote Originally Posted by MyDimeIsUp View Post
    Did you find that PDF by chance? I've been looking into the transfer case oil and can't seem to find anything official saying putting regular 75W-90 is okay (for refills). What I found so far is a picture from what seems to be an Audi service manual that says to use the gear oil w/ 4% Sturaco (G055145A2) on both initial fill and refill (see image below).
    I also found a ZF PDF about which transmission fluids to use: https://aftermarket.zf.com/remotemed...e-ml-11-en.pdf
    If you go to page 4 of the PDF and look beside the 8HP55A, there's a little "(2)" footnote. If you go find it on page 6 it also says to use G055145A2 oil for what they call the transmission's rear diff (car center diff). Granted it does only say "filling" and not re-filling on that one.
    I really want to be able to put regular GL-4/GL-5 oil in my transfer case since the cost is like 5x less and I have it on hand but at the same time, I don't want to risk damaging it. If you or anyone can find something from ZF stating regular GL-4/GL-5 is fine for refills, I'd greatly appreciate it!
    In the meantime, I'll keep researching and update if I find anything. Thanks!
    --Update--
    I found another thread where user djn876 claims having emailed ZF and they responded saying that the oil with friction modifier is recommended.
    Direct link to thread comment (#36): https://www.audizine.com/forum/showt...1#post14437261
    Just to be safe, I'll probably go with the Ravenol AWD-TOR since it has the special additives and tested to be better than OEM at a lower price (still comes out to about $85 w/ tax & shipping ). I guess the silver lining is I'll be able to get 2 changes out of the 1L bottle...
    Sep 12 2022
    Syracuse, NY
    I plan on doing all of these. I’m hearing a whirring/whining noise under acceleration starting at around 30mph, hoping it’s not one of my diffs. Guess I’ll find out when I drain them. Might also check the driveshaft carrier, saw something on another thread where a similar sound turned out to be that. So any gl4/gl5 75w90 can be used for the diffs and I should use the special one for the center diff/transfer case?
    Nov 27 2018
    Valparaiso, IN
    I put regular gl5 in my center and had no issues. Had close to 30,000 miles on the fluid when I traded the car in with no issues
