all three. I bought this kit:
https://www.blauparts.com/audi-a6-di...ferential.html
BLAU Audi A6 Quattro Differential Fluid Change Kit with Standard Non-Sport Rear Differential Includes:
Front Differential Fluid - Qty 1 - 1 Liter Bottle - RAVENOL VSG Fully Synthetic 75W-90 GL-5 Gear Oil. High performance replacement gear oil compatible with the original recommended front Audi differential oil specs. (Capacity 1 liter, 1.05 quarts)
Rear Differential Fluid - Qty 1 - 1 Liter Bottle - RAVENOL VSG Fully Synthetic 75W-90 GL-5 Gear Oil. High performance replacement gear oil compatible with the original recommended rear Audi differential oil specs. (Capacity 1 liter, 1.05 quarts)
Torsen Center Differential Fluid - Qty 1 - 1 Liter Bottle - RAVENOL AWD-TOR Fully Synthetic Gear Oil. High performance replacement Torsen differential oil compatible with the original recommended center Audi differential oil specs. Specifically formulated as an improved Audi Torsen center differential fluid. For more info regarding the benefits of RAVENOL AWD-TOR fluid, see
www.ravenol.de under company oil tests. (Capacity 1 liter, 1.05 quarts)
