Update: pics here https://imgur.com/a/D4i4Czt
I am having trouble with a coolant leak in my 2008 A4 2.0T Quattro with 165k miles. I recently replaced the coolant flange and sensor last month due to a leak, but now I have a leak at the front of the engine, slightly to the passenger side. Unfortunately, I cannot locate the source of the leak as it is difficult for me to see due to an old injury causing back pain. However, I have noticed that the leak only occurs when the engine is cold. When I drive the car, there is no noticeable loss of coolant, and I do not see any puddles or a low reservoir. But when the car sits for a few hours or overnight, it leaks a small drip that eventually leads to a visible puddle, and the reservoir becomes nearly empty after a few days of sitting.
Before attempting to replace the water pump and timing belt, is there any other component in the area that I should check that could be causing the leak only when the engine is cold?
