Results 1 to 7 of 7
    Junior Member Two Rings
    Jun 09 2011
    St Louis
    2016 3.0 - basic suspension replacement
    2016 Premium Plus 3.0T w 50k miles on the clock. Everything is stock except an EPL stage 1.
    Got a loaner the other day (23 Q5) and noticed the suspension was way smoother even on lower profile tires w bigger rims, so thinking the suspension might be getting a little beat after 7yrs. What would be your choice for replacing all four corners if I just want to improve the ride - i dont need to lower it and definitely dont want it stiffer (all city driving and pothole surfing). What is a good quality oem-like setup without being junk (and not oem price)?
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The Gen-2 Q5s (2018 plus) have softer suspensions than the Gen-1 Q5s, hence the more comfortable ride, at the expense of sharper handling.
    Sep 24 2014
    Central NJ
    Jul 16 2018
    Atlanta
    Without denoting the actual PR code for the suspension, it's "some suspension, no idea which". Could be steel springs or air springs, could be fixed dampers or adaptive dampers, could be standard components or sport components, etc.
    You need to know your PR code when going to look for parts anyway. It'll be on the vehicle identification sticker in the documentation. Three character code of 1B? or 2M?.
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Quote Originally Posted by redline9k View Post
    Believe it or not, the Q5 has 16 different spring and 11 different shock absorber
    Jun 09 2011
    St Louis
    ah sorry, just the standard 1BA suspension - all 1* codes -
    PRCode: 1AT = Electronic stabilization program (ESP)
    PRCode: 1BA = Standard suspension/shock absorption
    PRCode: 1LE = Disc brakes front
    PRCode: 1SH = Additional engine and transmission guard
    PRCode: 1XX = Leather trimmed multi-function sports steering wheel w/ Tiptronic
    Jul 16 2018
    Atlanta
    I presume that's your Q5. But was the loaner also 1BA. If they're both 1BA "standard coil spring suspension", then the difference is not due to different suspension configurations. And if wheel/tire/pressure config was the same, then possibly due to aged vs new, or more likely simply an 8R (B8 Q5) to FY (B9 Q5) difference, as S4'd presented.
