Results 1 to 8 of 8
    Oct 02 2023
    Arlington, VA
    B9 S5 Downpipe Install
    Hello,
    Recently purchased the IE Downpipe for my S5, and debating between doing it myself or bringing to a shop. Install looks straight forward, aside from the 2 hard to get bolts.
    Any advice on the install in general?
    Also, what should I look for as far as install costs for a job like this?
    Dec 29 2020
    Highland Village, Texas
    If you can get the front end up in the air, just do that and pull off the front 2 shields. It makes the job much easier, assuming you don’t have tree trunks for hands and arms as it’s a bit of a tight fit.
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Four of the six bolts can be reached and completely loosened from above. The remaining two, one on each side, I needed to get from below after disconnecting the downpipe from the hanger. IMO an S-wrench is the key tool here - I was able to get it all done with it and maybe a stubby IIRC, but did not need any socket/wobble/extension setups as some folks did. Whatever works!
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Search my posts, I have a complete guide out here somewhere
    '18 S4 Prestige; all packages
    Junior Member Two Rings
    Jan 28 2023
    1985 Porsche Turbo RSR Tribute, 2001 996 Turbo, 2001 Aston DB7 Vantage Volante V12, 1955 Lincoln
    It’s doable no problem on your own. I have quite a bit of experience, but it was not that tough compared to others I’ve done.
    Ian@SEM
    https://www.strictlyeuropeanmotors.com
    *Check us out for your VW and Audi Parts and Service*
    2020 Audi S5 Sportback
    2001 Porsche 996TT
    2001 Aston Martin DB7 Volante V12
    1985 Porsche RSR Tribute 3.5TT
    Dec 29 2020
    Quote Originally Posted by Ian@SEM View Post
    Agreed. It is an absolute cakewalk compared to the B8.5.
    Oct 02 2023
    Arlington, VA
    Thanks for the advice everyone! I will definitely try to do it myself!
    Established Member Two Rings zztroyzz's Avatar
    Jun 27 2010
    Ontario, Canada
    Hit the bolts with penetrating oil. Mine were very hard to get started.
    I ordered a C ratchet wrench that I thought would work better than an S wrench but they shipped me the wrong size so I did end up using an S wrench. I still think the C shape would have been easier to get better leverage on.
