Results 1 to 18 of 18
    Jan 24 2013
    💥WedsSport TC105x 18x9.5 +45 @17lbs each in 5x112 for RS3💥
    💥WedsSport TC105x 18x9.5 +45 @17lbs each in 5x112 for RS3 & TTRS💥
    🔥BACK IN STOCK🔥
    I worked with Wedssport to bring these to market specifically designed for the platform.
    I saw the need for a properly load rated, super light, strong, off the shelf option in a good spec that clears the brakes without a spacer. Those 20 sets sold out right away so more were needed.
    Here you go!
    -Clears RS3 8V and TTRS 8S steel and CCB
    -Can be paired with the 9.5 +25 on the fronts for the RS3 8Y steel brakes.
    -Comes titanium finish standard
    -Custom finishes can be done upon request.
    [email protected]
    The details:
    TC105x 18x9.5 +45 5x112 @ 17 lbs each
    Face R
    Knurled bead
    $2640 set 4 to lower 48
    TC105x center cab/hub ring combo:
    $240 set 4
    Black cone seat bolts if needed:
    $4 each
    Email: [email protected]
    Call or Text: 914-243-1993
    Senior Member Three Rings NapalmEnema's Avatar
    Jul 02 2022
    2022 Kyalami Green RS3
    Houston
    Will these fit an 8Y?
    2022 RS3 Kyalami Green
    2017 M2 Performance Edition - Arctic White
    2021 Type R - Shadow Grey Pearl
    Jan 24 2013
    Quote Originally Posted by NapalmEnema View Post
    Yes the 9.5 +45 on rear and the 9.5 +25 on front is solid for 8Y steel brakes.
    Lmk!
    Jul 02 2022
    Houston
    Got the ceramics thanks though!
    Junior Member Two Rings
    Oct 31 2016
    Boston, MA
    I had the 8.5" version on my car and the weight reduction was immediately noticeable coming from stock wheels. You will definitely feel an uptick in responsiveness on an 8V. They also cleared my AP-Essex brakes but just barely. Highly recommended even rolling around on wheels that weren't properly load rated!
    Jan 24 2013
    I have 18” that clear 8Y CCB if needed. Lmk.
    Jan 24 2013
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Killer wheel being so big and weighting so little. With these wheels can I run technically a square set-up?. I am trying to get away with the retarded reverse staggered set-up on my 8Y. I understand the new Audi RS3 has the wider track in the front and hence you are offering the assorted 25 and 45 offset. I just want a combo in which I can run the same size tires while still looks aesthetically appealing. I found the reverse staggered set-up absurd and ugly.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Jan 24 2013
    I think the 25 and 45 give you exactly what you’re looking for. Square rim and tire widths and looks good as it sits with fenders.
    That said, you could run the 9.5 +45 square but it looks terrible up front imo. The front fenders absolutely swallows the wheel. Sits way too inboard and ends up having that look you’re trying to avoid with the reverse stagger…just now it’s up front instead.
    Another consideration is strut clearance. 9.5 +45 up front is getting close to it and especially with 265s.
    Sep 21 2021
    AZ
    Quote Originally Posted by Paul@SupremePower View Post
    Could you go 9.5 + 45 with a 20mm spacer in the front? That'd turn it into a 9.5 et25 right?
    Jan 24 2013
    Quote Originally Posted by Kemora View Post
    Yep a lot of my track guys do that. Allows you to rotate and nets the same good stance for track.
    Sep 21 2021
    AZ
    Thanks for confirming! Still get the occasional brainfart when it comes to spacers and et's.
    Nov 06 2015
    Campbell/CA/USA
    As usual Paul went above and beyond! A few months ago Paul got these shipped out very quickly so I could make a couple track days. The wheels look great and are incredibly light. I have hit curbs without issue.
    I did overheat and glaze my front rotors and melted the stickers off the center cap/hub ring, can't blame them due to the heat.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Jan 24 2013
    Quote Originally Posted by AKArustywheeler View Post
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Woot! Nice work!
    High temp epoxy works to reattach the center if it’s not completely shot.
    Active Member One Ring Wtbmerlin's Avatar
    Jan 11 2022
    SW IN
    What is the wait on a set of the high polished look or a bright silver in the 8v2 rs3 fitment? Are you going to run a black friday on them?
    2018 RS3 Velvet Purple - stock AF
    Jan 24 2013
    Yes $2499 on a set. I have stock arriving in a few weeks.
    17lbs each in 9.5 +45
    Feb 19 2023
    19 RS3, 22 Maverick
    Cleveland
    Sending you a PM with some questions, as I may be interested!
    Established Member Two Rings gpm24780's Avatar
    Mar 16 2019
    2017 Audi Q7
    ROYAL PALM BEACH
    How much does the stock 8Y RS3 rim weigh?
