🔥BACK IN STOCK🔥
I worked with Wedssport to bring these to market specifically designed for the platform.
I saw the need for a properly load rated, super light, strong, off the shelf option in a good spec that clears the brakes without a spacer. Those 20 sets sold out right away so more were needed.
Here you go!
-Clears RS3 8V and TTRS 8S steel and CCB
-Can be paired with the 9.5 +25 on the fronts for the RS3 8Y steel brakes.
-Comes titanium finish standard
-Custom finishes can be done upon request.
[email protected]
The details:
TC105x 18x9.5 +45 5x112 @ 17 lbs each
Face R
Knurled bead
$2640 set 4 to lower 48
TC105x center cab/hub ring combo:
$240 set 4
Black cone seat bolts if needed:
$4 each
