Hi all, the allroad has had a bit of work done a while ago (3000mi), with upper and lower control arms having been replaced, the left hand outer cv as well as the airbags quite some time ago before that.
I haven’t yet done tie rod end or sway bar links, but I believe there was a little slop in the tie rod ends.
In the last couple of weeks it has developed an unusual popping or knocking noise on the left side (of a right hand drive car) which is loud enough to hear in the cabin with the radio off if you’re paying attention. You can also if very careful, just feel a little bit of vibration in the floor.
It doesn’t happen 100% consistently. It doesn’t appear to be related to how hard bumps the car goes over. It doesn’t get any louder with big bumps vs very small. If you’re on the highway going straight it won’t knock at all.
It seems to pop a bit more often when the suspension droops, but will sometimes do it in compression like when turning right into a driveway, but generally seems to do it more when going left or straight over moderate undulations. Again not 100% consistent even when driving over the same road.
I have tried bouncing on the front end while static without being able to create the noise. I have also tried turning the steering wheel when static, and am not sure but there may be a very subtle noise on directional change.
Does anyone have a view of most likely culprits? I haven’t yet had the time to setup a GoPro or something in the wheel housing to try and diagnose further.
