Results 1 to 16 of 16
    Established Member Two Rings Hagasan41's Avatar
    Sep 16 2013
    Orlando
    Check engine light code P2015
    Need some help Audi gang. My check engine light came on and when I pulled the codes I get P2015 “ Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 1”
    Planning to purchase a new intake manifold sensor. Looks like it’s a PITA to replace from the YT vide as the intake manifold needs to be removed to gain access. Anyone have additional tips or tricks? Do I need to replace the intake manifold gaskets, etc or can I simply reuse? The car only has 54k miles and runs great. But I can’t stand the check engine light! Thanks in advance
    2015 A4 Quattro S-line 6MT Glacier White/Black
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Replace the entire manifold. Or do that, then the solenoid, then get that dumb little linkage repair, just to find out every pivot is worn and it'll never meet commanded. The vw ones used to be a cheaper option but it doesn't look like it anymore
    Jul 16 2018
    Atlanta
    To check the sensor, if you have VCDS, bring up the load flaps measuring value under 01-engine. See what the reading is. Manually move the lever arm on the back end of the intake manifold and see if the value changes accordingly. Should be ~10% "at rest" and ~100% when you fully move the arm.
    The common failure of the intake manifold resulting in a P2015 because it broke and the arm is falling out of the IM shouldn't be a problem on a MY15. If you don't have rough idle and misfires, then at least the arm hasn't come out enough to create an air leak.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Ive never seen the sensor fail. It's always the linkage or the vac circuit.
    B6 S4, B8 A4, 8P A3, and something, something.
    May 12 2017
    Quote Originally Posted by apeck240 View Post
    I wish I listened to this advice the first time around. I had a shop tell me it was the ECU. Swapped the ECU and still had the problem. Then swapped the solenoid, still didn't fix it. A year later I ended up just swapping out the whole manifold and voila, no more CEL or P2015 code.
    AKA: hcuorG
    Nov 30 2016
    B8.5 allroad stock for now. B6A4 avant
    northfield, ma usa
    I had that same code it was the vacuum solenoid. Part was 80 or so on FCP
    Sep 10 2018
    N.W colorado
    I had the 2015 code, it was a small tear in a vacuum hose, also an $ 80 part
    Sep 16 2013
    Orlando
    Thanks guys for all the input. Ended up just dropping the car off at the dealer to diagnose as I don’t have the diagnostic equipment and or time. We shall see what they say…
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    Great info. Any update?
    Aug 25 2020
    Glendale California
    I have code p2015 and check engine light change the whole runner and the sensor from Audi and still have check engine light. What could it be? I have 2015 Audi all Road.
    May 31 2023
    Stroudsburg, Pa
    I'm curious on this as well, same code P2015 (2010 A4 bone stock except CTS Catch can and PCV delete and Silicone charge pipes) before and after having installed new Manifold, Potentiometer, flap runner solenoid, purge valve solenoid, all vac lines and check valves, intake air temp sensor. Only thing left is the original throttle body and the vac pump.
    2010 A4 Quattro 6MT Premium Plus
    Sep 25 2016
    Philadelphia
    You might want to take a look into this part here: https://www.ecstuning.com/b-ecs-part...021071ecs01~a/
    I had the P2015 code recently and haven’t gotten it since I installed this part.
    Nov 30 2016
    northfield, ma usa
    The vacuum solenoid that controls the flaps. When I had that code the solenoid was seized up
    Sep 25 2016
    Philadelphia
    Just as an update, I have to change my manifold because the manifold itself was damaged.
    Apr 01 2021
    Interesting
    Sep 16 2013
    Orlando
    Forgot to update the thread… so took the car to my local Audi dealer. They run their diagnostic and of course come back with the manifold needing to be replaced to the tune of $3668 including walnut cleaning for $495. Parts alone was $2002! Of course I laughed, paid the $200 fee and purchased the necessary parts including the manifold, gaskets, o-rings ,etc on FCP and ECS Tuning for $4xx. The parts list they provided was helpful, but also included double charges like a separate charge for the manifold gasket that’s already included with the new manifold.
    Well, whatever they did cleared the code because it’s been a few months and it’s hasn’t come back. Either way I have the parts to do it myself…
    Thanks to everyone for the help.
