Originally Posted by
JimmyM531
What issues were you having with your a6 tdi at the 125k mark? Just curious as to what was becoming so costly.
Here are the service records for my old 2015 TDI.
135,845 – 12/2/21 – Replace Oil Cooler
125,999 – 6/4/21 – Replace G784 Particulate Sensor
123,596 – 4/8/21- Ad Blue Pump, Differential Pressure Sensor, Reductive Agent Injector, Reductive Agent Tank
123,596 – 4/8/21 - Replace Rear Right Light Assembly
119,682 - 12/11/20 - MMI Screen Monitor
118,423 - 11/11/20 - NOX Sensor
110,976 - 5/22/20 - Glow Plug
108,592 - 4/7/20 - TDI FIX
104,376 - 1/10/20 - Front Brakes (39,000) Rear Brakes (31,000)
99,810 - 10/14/19 - Exhaust Clamp
94,812. - 7/22/19 - Motor Mounts (replaced differential and transfer case fluids - not part of price)
93,405. - 6/19/19 - Driver’s Front Seat Cover
73,486 - 4/20/18 - Rear Brakes (35,000)
70,041 - 2/9/18 - ATF changed, Coolant Changed, All Struts changed
65,242 - 11/6/17 - Front Brakes
62,493 - 9/27/17 - Right Rear Wheel Bearing
58,911 - 8/3/17 - ACC Brake Guard Inoperable, Replaced Diver Door Lock Actuator, 4 Wheel Alignment
55,228. - 5/30/17 - Driver Side Mirror Housing
49,859. - 3/6/17 - Replaced Sunroof Shade Liner, Front Sway Bar End Links
38,470. - 8/17/16 - Rear Brakes
35,802. - 7/14/16 - Replaced Rear Sunshade
28,956 - 4/18/16 - Replaced Rear Sway Bar End Links
28,478 - 3/23/16 - Replace Rear Right Light Assembly
