Results 1 to 8 of 8
Thread: MK8 PCV
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    MK8 PCV
    Has any tried running the MK8 PCV valve as a replacement for the OEM BL revision?
    I am getting lots of smoke after hard cornering with my latest suspension and tire mods, so I now understand why some track-rats insist on having a catch can.
    From this article it looks to be a good potential solution: https://www.datadrivenmqb.com/drivet...k8pcvtracktest
    2019 SQ5 Prestige
    Junior Member One Ring
    Oct 16 2021
    East Coast, USA
    I was literally just saw his video and reviewed the test results which seem promising. I'm curious about the fitment on a tuned 8V with an upgraded turbo, DV, inlet and intake.
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Quote Originally Posted by MikTip View Post
    I've heard of this but never seen any info....my main question would be whats the vastly superior reason to go to the newer pvc aka oil seperator over its older version????
    Also if a person looks at the factory pvc/ oilsep plate on the LM RS3 with its factory S3 engine...you can see what the factory race cars run🤪
    The hidden aspects of this system in the catch can and the return valve that returns oil into the engine. 034 has a simuliar oil return setup...
    Have you seen this video?
    https://www.youtube.com/watch?v=jYdF-sOLe3I
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Apr 01 2007
    houston texas
    MK8(Also found on Audi A7)
    Which part number are you seeing for the A7?
    2019 SQ5 Prestige
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    B9 plate works really well and bolts up!
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Apr 01 2007
    houston texas
    Good catch! So the PCV plate itself is the commonly referenced B9 plate, but the hose to the tip with the extra vac line is what is a new development and *may* be beneficial.
    I am currently running the 06K 103 495 BM which is the A3 S3 TT TTS specific PCV. It didnt like all the hard cornering and Gs..
    https://parts.audiusa.com/p/73357674/06K103495BM.html
    2019 SQ5 Prestige
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    I've been running the mk8/b9 pcv for a couple weeks but have yet to test it on track. 31psi tune w/ hybrid turbo. For city/street driving it's been fine.
    From following the PCV drama on golfmk7 for a while, generally people like BL revision more than BM, but the new b9/mk8 pcv seems promising, though not a cure-all on the track. Indeed thinking along lines of @MikTip about replicating the TCR setup, I think one key is that the CC/AOS is located behind the engine and avoids long hoses. Trying to figure out a way to source those parts - saw one listed (sold) online - https://es.wallapop.com/item/oil-cat...eite-831286196
    Oct 16 2021
    East Coast, USA
    Quote Originally Posted by yakev724 View Post
    How did it work on track and daily street driving?
    - - - Updated - - -
    Latest update and more user feedback on the MK8 setup:
