I got you on this one. Had to play this game a few years ago... you can easily make your own caps using the Alzors and Audi's.
The Alzor centers are just a flat disc attached by an adhesive. From the back, work a flathead in to free the center...pry them up and off. Then pop out the Audi centers and adhere those to the Alzor caps.
From here you've got two options. Since the Audi centers have a rise to them, you'll either need to shave them down flat (to be like the Alzor centers) or if you like the rise find some kind of material to take up the space. The 1st time we did this my buddy shaved down a set for me and they sat flat. The 2nd time, just left them as is and used those pads that go under table legs to take up the space which actually worked incredibly well (the adhesive will seal them). I would def reco the latter... super easy and IMO it looks better.
Be sure to use JB Plastic Welder as the adhesive. It's more gooey than runny so far easier to take up the space between the two pieces, and very forgiving if you need to wipe some away in the process.
As for longevity, The first set I made lasted maybe two years until the Audi centers we used started turning yellowish. They were from an old set of B6 wheels. 2nd set is still currently on my B7, three+ years now. Will grab some pics...
1st set shaved flat. We used a bench grinder.
Current set, no modification to the Audi center. I like these better.
