This is seriously stressing me out.
I'm in the process of trying to replace my front upper control arms. First side was an absolute nightmare, but i managed to get the pinch bolt off after snapping off the bolt head, by tightening a nut the other side, with an oversized nut as a spacer, then cutting a bit off the bolt, adding another oversized nut, tightening until i ran out of thread, then using a spare pinch bolt hammered out the last bit.
The other side however does not want to play ball. Ended up rounding the head of the bolt and couldn't snap it off so had to cut it off (and accidentally cut slightly into the knuckle). Then tried the previous method until i ran out of thread, at which point no amount of hammering would shift it even a fraction of a mm. Got so many little cuts and dings in the knuckle, i really hope it doesn't cause it to fail it's MOT.
Current situation, totally rounded nut:
Only car in the household, past the point of driving to a garage and MOT coming up in a few days. I've read about people using a C/G clamp with a nut bit to turn it rather than a handle but can't seem to find them for sale anywhere. This is what i mean:
I've ordered a normal G clamp to tighten a bit of bolt through one end and push the remainder through the other but i don't think i'm going to get the force i need with just a handle to turn:
I've ordered this:
But i have a feeling that's just going to bend from the pressure and i ordered some cobalt drill bits as a last resort to try and drill it out. Also got some dremmel cutting discs to cut the bolt through the slit in order to hopefully get the end bit out so there is less to drill.
Anyone got any other suggestions to get this damn bolt out? Heating isn't really an option as everyone says don't ever heat aluminium.
Edit - Actually managed to find the clamp with the nut end in a ball joint press kit. Hopefully that will work a lot better:
