Results 1 to 6 of 6
    Mar 24 2016
    Salt Lake City, UT
    Smile 034 Motorsports Mods
    Back in mid-April 2023 I took delivery of a new 2023 S5 Sportback. I modified the car from the start with 20" dia x 10" wide Avant Garde M580 wheels and Michelin Pilot Sport AS4 275/30-20 all season tires (decided to forego winter/summer tires based on my experience with my previous 2014 S4).
    Prior to the Audi's delivery, during its spring sale, I bought a thicker rear anti sway bar, front strut brace, and transmission mount from 034 Motorsports. Last week I finally had all three installed. I wanted to wait and drive the car for a while so I could more accurately assess the difference the mods made.
    Here are my observations, FWIW.
    Sway bar: car corners slightly flatter and with a bit less understeer. It's only noticeable during hard cornering, but it's very nice. No noticeable degradation in ride quality.
    Strut Brace: The improvement in steering feel and precision from the strut brace is barely detectable, but it is there if you look for it.
    Transmission Mount: The transmission mount was a shocker. The transmission shifts are clearly crisper and there is noticeably less slop when shifting, particularly in sport mode. This pretty much confirms what many others have posted on this forum about the transmission mount change.
    Overall, I'm quite happy with the mods and would highly recommend them.
    Senior Member Two Rings Z06Corey's Avatar
    May 24 2019
    Looks good 👍
    2019 S5 SB. Prestige, black optics, B&O, sport diff. 034 stage 2/2 ECU/TCU, 034 downpipe, APR intercooler, 034 transmission insert, 034 turbo inlet, CTS intake
    2017 R8 V10+
    Feb 20 2023
    Northbrook, IL
    Thanks for posting your impressions. I am about ready to add a RSB and appreciate your feedback. I had wondered about the strut brace. Even watched a couple YouTube videos and felt bad watching the people try to explain their perceived differences with the new strut brace. There is no doubt in my mind that a thicker RSB will change the cornering characteristics but am unsure about the strut brace. I think you would need to be at the limit to notice the improvement from the upgraded strut brace and in my case, when tracking the car, that would be a solid upgrade.
    For the price, the question for me is: do you upgrade the RSB and perhaps the strut brace OR do you get a FSB and RSB and forget about the strut brace.
    CURRENT: Quantum Grey 2019 S5 Sportback Prestige, Black Optics, S Sport Package
    Neuspeed RSe102's, 034 Trans Mount Insert & tranny mount upgrade, ABT HAS, 034 intake and inlet, 034 Stage 1 ECU/ Stage 2 TCU tune, 034 front strut brace, 034 subframe and diff mounts, 034 RSB, 034 RSB & end links, iSweep IS2000 pads, Neuspeed braided SS brake lines, Wagner Comp intercooler, more to come...
    GONE BUT NOT FORGOTTEN: 2017 VW GTI SE, highly modded and tracked.
    Jan 08 2018
    24 RS5, 24 A6 Allroad
    Twin Cities, MN
    I did notice a difference in stiffness with the front strut brace as far as low speed noise goes. Spots like driveways and uneven neighborhood streets that would make the car creak before no longer creaked after installing the upgraded brace. It also looks great under the hood.
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by Rocket2 View Post
    Strut brace is subtle, but I noticed less overall body flex. Transmission mount has to be the best bang-for-the-buck mod ever !! What a game changer. Haven't done sway bars. Can someone tell me how the stock RS5 sway bars compare to the stock S5 sway bars?
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by VVG View Post
    The sway bar is shared between many of the A/S/RS models.
    https://parts.audiusa.com/p/Audi_202...0511305AL.html
    My S4 came with the blue marked 19mm bar, as would an RS5.
    , 19.6 mm. , 19.6mm. 19.6 mm. 19.6mm. A5; Blue Marked 19mm. A5; White Marked 19.6mm. CONVERTIBLE, 19.6mm. Coupe, 18 mm. Coupe, 19.6 mm. RS5; Blue Marked 19mm. RS5; White Marked 19.6mm. S4. S5; Blue Marked 19mm. S5; White Marked 19.6mm. W/AWD, 19,6 MM. W/O AWD, 18 MM.
    That said, The Rear Sway Bar kit is certainly a game changer in terms of handling performance. If you're looking to take it up a notch, the Front & Rear Sway Bar kit is makes worlds of difference, even over our RSB kit. It includes an even larger rear sway bar and perfectly matched front sway bar - and is what we run on all of our development vehicles.
    https://www.034motorsport.com/034mot...5-allroad.html
    -Sean@034
