Results 1 to 6 of 6
    Apr 30 2018
    CA
    8V S3 and 8V RS3 coilover interchangeability?
    Anyone know if coilovers are interchangeable for the 8V S3 and 8V RS3?
    Looking to grab some Bilstein B16 PSS10 for my S3, which I've decided to toy around with for a bit while keeping an eye our for a used RS3, hoping I'd be able to move the coilovers over if possible once I pull the trigger on the RS3
    Dec 25 2004
    Earth
    Quote Originally Posted by ilikecookies View Post
    The part number of the B16 PSS10's will tell you want they fit and if they are S3 and RS3 compatible.
    48-251570
    https://www.urotuning.com/products/b...#collapse-tab5
    Yes
    Audi A3 8V Sedan (2014-2020) 1.8T
    Audi A3 8V Sedan (2014-2020) 2.0T FWD
    Audi A3 8V Sedan (2014-2020) 2.0T Quattro
    Audi RS3 8V Sedan (2017-2020) 2.5T
    Audi S3 8V Sedan (2015-2020) 2.0T
    VW Alltrack Mk7 (2017-2019) 1.8T
    VW Arteon 2019+ 2.0T 4Motion
    VW Arteon 2019+ 2.0T FWD
    VW Mk7 (2015-2017) GTI 2.0T
    VW Mk7 Golf R (2015-2017) 2.0T
    VW Mk7.5 (2018-2021) GTI 2.0T
    VW Mk7.5 Golf R (2018-2021)
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 30 2015
    Tallinn, Estonia
    OEM suspension is the same for both I think (example is put code 8v0413029p into ecs), when changing the brake discs on my RS3 I noticed that the stock absorbers even have S3 written on them. Based on my research lowering springs for the S3 should also fit for the RS3.
    Had a similar case, where I ordered lowering springs and before they arrived managed to write off my S3 and replace it with an RS3.
    Apr 30 2018
    CA
    Bilstein looks to be interchangeable, but when looking at the KW v3, it looks like it's not, wondering what the difference is.
    Edit: got a response from KW, the valve and spring rates are vehicle specific
    Nov 13 2009
    the OC, SOCAL
    hey bro,
    didn't know you were looking to swap out your car?
    you didn't mention that last time.
    when you want get some suspension like bilstein let me know and ill get you the 48-251570. like I mentioned. i can do the best prices on any thing from bc racing, silvers, bilstein, etc.
    Apr 30 2018
    CA
    Quote Originally Posted by 949 View Post
    hey bro,
    It's a want vs need debate in my head right now in terms of changing cars lol
