Results 1 to 10 of 10
    Established Member Two Rings manxx's Avatar
    Sep 06 2012
    Question 00283 - ABS Wheel Speed Sensor; Front Left (G47)
    Got into the car today and after starting it up, Christmas lights came on earlier this year: Traction Control, Parking Brake Malfunction, Stabilization Control ESC/ABS Fault, Headlight range control defective.
    Connected VCDS and got these codes:
    Address 01: Engine (MY16-CAED)
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [047] - -
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [047] - -
    Address 03: ABS Brakes (J104)
    00283 - ABS Wheel Speed Sensor; Front Left (G47) <-----
    012 - Electrical Fault in Circuit - MIL ON
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory
    Address 05: Acc/Start Auth. (J393)
    01330 - Central Control Module for Central Convenience (J393)
    Address 09: Cent. Elect. (J519)
    01316 - ABS Control Module
    Address 16: Steering wheel (J527)
    Address 44: Steering Assist (J500)
    3164944 - Function Restriction due to Faults in Other Modules
    U1113 00 [009] - -
    Address 46: Central Conv. (J393)
    Address 53: Parking Brake (----)
    459520 - Function Restriction due to Faults in Other Modules
    U1113 00 [137] - -
    So it could be the front left ABS sensor, but then why all the other errors? Related/dependent? If this is caused by a weak battery (this is 2016 A4), why the battery energy management system is not on in the logs? I'm charging the battery now just to eliminate that as the cause (weird as the car was just driven with over 300km in the last few days so the battery would get charged).
    I see a lot of posts on this, from an actually bad ABS sensor, a short in the wire harness, broken/dirty magnetic ring, bad ABS module... to a bad battery.
    I'm going to take a look at the sensor/wiring shortly, was hopping to hear some feedback from those who had to deal with this issue, before I start ordering parts.
    Thanx!
    2002 Jetta 1.8T 5MT (sold), 2009 A4 6MT(sold), 2010 Golf 6 (sold) , 2012 A3 (sold), 2014 Q5 (totaled), 2015 Q5 (sold), 2016 A4 6MT (sold), 2020 Q5 Technik, 2020 S4 Technik, 2023 VW Taos
    Jul 16 2018
    Atlanta
    The rest of the errors, because that's how the stuff was designed. They are designed to create flags when they might have issues performing their tasks, but the root issue is not that module but a problem in another module. Specifically designed to make techs stop blind replacing modules that aren't broken.
    Sep 06 2012
    Looked at the wiring, nothing suspicious, checked the battery, should last a bit longer...
    Looked at live data, no input from G47:
    So it looks like it's the ABS front left sensor. I measured it's resistance, it was showing 4.5 ohms (looking to check what the value should be). Could not remove it, did some WD40 on it, would not budge - what is the best way to get it out? Pull on it? Twist it out? Maybe apply some heat on the housing?
    My only concern is why did it trigger headlight range control, are these component interconnected/dependent on the ABS sensor?
    Does anybody know a good replacement PN or OEM is the only way to go here?
    Dec 29 2017
    Phoenix, AZ
    Front left and rear right are the same. If you're still troubleshooting you can swap them around to isolate.
    I bought these for my B8 (2010) Avant:
    https://www.fcpeuro.com/products/aud...sor-4e0927803d
    https://www.fcpeuro.com/products/aud...sor-4e0927804d
    Sent from my Pixel Fold using Audizine Forum mobile app
    2010 Avant // 2015 Allroad
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    All sensors are the same, it's the connector stems that are molded different to angle the connector away from the brake rotor.
    Good luck getting them out in one piece. I broke all 4 of mine when I did my wheel bearings trying to get them out. Bought all new ones.
    If the sensor ohms correctly, it could also be your wheel bearing that went bad as its not picking up the pulses in the bearing.
    Sent from my SM-N976V using Tapatalk
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Sep 06 2012
    I'd love to swap them, but once they are in, the only way out is in pieces. I'm looking at the possible failure reasons in the Ross-Tech Wiki and hope it's the sensor itself:
    00283 - ABS Wheel Speed Sensor Front Left (G47): Electrical Fault in Circuit
    00283 - ABS Wheel Speed Sensor Front Left (G47): Open or Short to Plus
    00283 - ABS Wheel Speed Sensor Front Left (G47): Signal Outside Specifications
    00283 - ABS Wheel Speed Sensor Front Left (G47): Mechanical Malfunction
    If it was the magnetic ring or some dirt it would most likely show either "Signal Outside Specifications" or "Mechanical Malfunction". A shorted/damaged wire harness would show "Open or Short to Plus". I will measure the resistance of the sensor from rear right and most likely will order a new one. Getting out will be the scary part, I watched some videos on people drilling them out and putting a screw in to pull them out or crewing in a red-hot screw into it and then pulling out. If anything goes wrong, it will be a major pain.
    I should be able to just connect the new one and clear the errors before trying to swap it to see if that makes any difference.
    Sep 06 2012
    Update:
    Checked a local Audi dealer for 4E0927803F sensor: $ 188.37 CAD. Got the same BOSCH part from germanparts.ca for $38.60.
    Before I attempted to remove the old sensor, I quickly disconnected it and connected the new one, cleared all codes to make sure it is indeed the sensor that is the issue - no errors returned.
    Now was the hard part. The damn thing would not move, I soaked it for hours in WD40. After pulling and pulling ...it finally broke off. Had to drill a hole, put a screw in and pull it out in pieces (what a nightmare!). It could be worse though.
    Did a live data check, took it for a drive. Problem solved.
    Jun 12 2013
    Nice man! Happy you got it resolved!
    I think I mentioned earlier, you can't get those sensors out once in and with some good mileage on them. They just break. I've had to drill out the pickup in the bore many times. Use a file to deburr the bore, little bit of all purpose oil and the new one slides right in.
    Sent from my SM-N976V using Audizine Forum mobile app
    Build Thread
    Dec 29 2017
    Phoenix, AZ
    Quote Originally Posted by manxx View Post
    Update:
    Good lord...I've never seen any sensors come out like this.
    Glad you got it fixed!
    Quote Originally Posted by Allowencer View Post
    I've never seen these sensors like this. I have a B8, a B8.5, a Q7, and worked on quite a few others and never had a problem moving them around. I wonder if it's a "weather" thing...I live in AZ and my cars rarely see rain let alone snow or even a cold day, really.
    Jun 12 2013
    100% it's a climate thing lol. Northern states with salt and corrosion, this happens. Warm weather states, you have it easy. Lol
    Build Thread
