I have raw fuel smell after recent fill up (at $6.37 a gallon, thank you california).
I took the plate off and saw a bit of fuel adjacent to the pipe at 10 o clock.
I know there are two electrical connections and one fuel as shown.
I'm surprised to see that pipe at 10:00 is not covered / connected and there are no other lines hiding out of view.
What is this unused pipe used for?
Maybe fuel pump failure mode is to allow gas out this pipe?
Edit: A thread on B8 S4 forum says
– Press release tab and disconnect fuel line -2- at flange.
– Press release tab and disconnect fuel line -1- (if fitted) leading to metering pump for auxiliary heater at flange.
I guess I don't have -1.
Now I suspect that the cap or other connection is failing so I'll just replace the pump and see what happens
Thanks
