Results 1 to 18 of 18
    Junior Member Two Rings
    Mar 01 2023
    New York
    Exhaust help! Audi rs3 8V
    I want to get an exhaust for my car that wont drone and won't be too loud, Awe seems like it would be significantly louder, As I don't have midpipes and a UNI Dp. Any suggestions? How is the APR Exhaust?
    Dec 02 2020
    Austin, TX
    Just add some midpipes to it with the stock exhaust and see how you like it. Best mod that only takes 45 mins- hour to install.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Quote Originally Posted by Digodoggo View Post
    Why don't you just buy the test pipes and just use the exhaust switch from the console? you will have the car quiet or sportier. I tried the standard exhaust and the RS sport exhaust and I tried the stock pipes and the test pipes and in my opinion the test pipes are a great combo with the standard or sport exhaust. Save yourself some money.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Registered User Three Rings MerakiAutoworks's Avatar
    May 09 2016
    Orange County, CA
    I had the AWE switchpath on mine. Perfect exhaust. Didn't drone and wasn't too loud, sport mode with valves more open it was great.
    Have them in stock, can work you a deal on one. Text us!
    -Josh
    Senior Member Two Rings Fixeroh's Avatar
    Aug 13 2014
    Central Ohio
    I went with Milltek. Very happy. Quality through and through. Love the sound. Neighbors not so much but reasonable in standard drive mode. Sport mode sounds so damn nice without being obnoxious. Can find some reviews on YouTube with sound sample. Believe there are sound bites on the Milltek website as well.
    Veteran Member Three Rings signde's Avatar
    Apr 07 2019
    nashville, tn
    i love my switchpath when the valve is open, it sounds absolutely glorious. there is a tiny bit of drone though. with the valve closed at 75 on the freeway there is a resonance that was not there with the oem setup. it's minor, but i notice it.
    if you get the switchpath and do not have a tune that opens both flaps all the time in sport mode, be prepared to get a valve controller two because the passenger side valve behavior is dumb.
    Audi 8V RS3 | Porsche 997.1 Turbo | VW MK4 R32 | Porsche Macan Turbo
    Senior Member Three Rings Cool_Breeze's Avatar
    Feb 22 2020
    San Jose, Ca
    +1 on trying midpipes first. That brings the right amount of sound into the cabin at higher rpms and no drone at all. Plus it’s super cheap and easy to install yourself.
    May 09 2016
    Orange County, CA
    Midpipe did help but still wasn't enough for us! haha
    -Josh
    Veteran Member Three Rings RS3TP's Avatar
    Dec 22 2018
    Richmond Hill, Ontario
    Mid pipes sound to be the right choice for what you are looking for. I put them on my car and they are perfect.
    Nov 27 2020
    Florida
    Valve controller (E.G. CETE or awe) and/or tune that opens valves in sport mode all the time (E.G. Uni) is something else to consider. Midpipes and valve controller also probably only enhance a cat back exhaust so worth trying first. I'm 100% good with midpipes, CETE valve controller and uni tune. CETE (or awe) is nice because you can undo valves open in sport mode if you want rowdy driving but not rowdy sound or have a dogbone mount that doesn't like idling below 1k rpm (most nvh of rpm band in my experience).
    Mar 01 2023
    New York
    Do you find them to drone at all, do you also have midpipes?
    Senior Member Two Rings fzr100098's Avatar
    Nov 09 2022
    Charlotte
    APR....a little louder than stock but not obnoxious at all. Retains stock valves in same positions and dual exhaust all the way back (vs single pipe)
    2023 Tango Red RS3
    Senior Member Three Rings NapalmEnema's Avatar
    Jul 02 2022
    2022 Kyalami Green RS3
    Houston
    I have the pipes it's a good stopgap but I'm going full send on an exhaust early next year. This car needs moar sound. Sport exhaust is a joke I think it was quieter than my Civic stock. Looking at Provocateur best I've found sound wise -
    2022 RS3 Kyalami Green
    2017 M2 Performance Edition - Arctic White
    2021 Type R - Shadow Grey Pearl
    Nov 09 2022
    Charlotte
    I don't speak German - how much is it?
    2023 Tango Red RS3
    Jul 02 2022
    Houston
    Quote Originally Posted by fzr100098 View Post
    Pretty spendy I think around 3500 to get it stateside.
    Jul 20 2021
    Atlanta,Ga
    I put in Milltek. It has the same sound as stock,just slightly louder. These cars don't seem to really respond much to exhaust upgrades. If I was doing it again, I'd probably just put in midpipes myself, it's a lot cheaper.
    Feb 10 2023
    2022 RS3, 1980 CJ5
    US
    Quote Originally Posted by BeastMaster View Post
    Which Milltek system did you get? Resonated, non resonated, race non resonated? I am tempted to get the race non resonated. Still a small muffler on it but straight through when the valves are open but I am curious about how it sounds with the valves closed.
    Jul 20 2021
    Atlanta,Ga
    Quote Originally Posted by PlanetExpress View Post
    I got the resonated, as I didn't want to risk being non-street legal. I took it to Road Atlanta on a Sunday and was flagged for noise violation during the track's "quiet time hours". However, that was in Sport. Once I put it back to Dynamic, they let me back on the track, so it is a lot louder in Sport mode. However, I almost never use Sport on the street because of the higher RPM shift points as I don't want to drone too much as well as tank my MPG. So if you're just cruising in anything but Sport, an aftermarket exhaust probably isn't worth it. The Milltek cost me $1800+install, and that was when it was on sale.
