Results 1 to 19 of 19
    Mar 16 2023
    Audi: Adaptive Light Malfunction, changed blown bulb, warning still present.
    Changed the H7 bulb on driver's side, but checked both with multimeter. Error still comes up in screen between gauges, my Motopower OBD tool doesn't see the error and can't erase it. Do I need to buy another diagnostic tool? Will MMI reset fix this? Negative terminal? I don't have a Windows laptop so VCDS isn't really an option.
    Veteran Member Four Rings Ozone510's Avatar
    Feb 15 2016
    Audi A4 B8 Avant 2.0T, Audi A4 B7 2.0T SOLD, Audi TT 8J Cabriolet VR6 DSG
    Hayward, California, USA
    OBDeleven is solid. Try that
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    Mar 16 2023
    Quote Originally Posted by Ozone510 View Post
    I did, it doesn't see that error. It's not a CEL or anything on the dash, just a message on the screen.
    Feb 15 2016
    Cambridge,Ontario
    as far as i know just replacing the bulb should fix it. does not require any clearing. very odd, are there any other lights out ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    This is B8.5?
    If you have a message about a problem with the front lights, there is going to be a DTC in the J519 (09-central electrics). Does the message present at ignition on, at engine on, at headlamps on? Put the switch to off or on, not auto, when trying to sort this. Usually, the bulb errors only present when the bulb is invoked.
    Message or not, does the lamp actually function?
    The bulb is not driven directly by the J519. It's powered by the control module on the headlamp, which the J519 talks to via private CAN. But unlike B9 where the headlamp modules are accessible from the gateway, I do not believe the J667 / J668 modules for B8 AFS are addressable directly by gateway.
    https://www.ilcats.ru/audi/?function...10&language=en
    module 4 drives the HID bulb
    module 5 drives the LED lights
    module 6, only with AFS, drives the HID movement motors and the static cornering lamp
    I believe 4 and 5 are on the bottom, 6 is on the side.
    Mar 16 2023
    Quote Originally Posted by Smac770 View Post
    This is B8.5?
    Engine or ignition on, headlights do their dance, 10-15 seconds later I get Audi: Adaptive Lights malfunction. It's the cornering lights, well, only the drivers side that blew. Both bulbs replaced, both were tested by multimeter before going in because I didn't want to take them out again. Error appears with all light modes. Bulbs do not turn on under any circumstance.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Bolshoi View Post
    You have to clear the code with something otherwise it will constantly say the bulb is malfunctioning. Went through this a few times and just changing a bulb will not clear the code.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Jul 16 2018
    Atlanta
    Once this message comes up, "Audi: Adaptive Lights malfunction", there has to be a DTC in the control module. It would make no sense to have an error message and not have an error code. Should have been an 02235 it seems (which is a DFCC, not a P code, but they're all DTCs).
    https://www.audizine.com/forum/showt...1#post13972336
    As mentioned, there's a few times where the code simply being present will prevent operation, and the code has to be cleared once the errant condition is amended. Or you have to do some many drive cycles before it self clears.
    Oct 21 2022
    Sydney
    Quote Originally Posted by bakedziti View Post
    I don't see clearing code helps in this case.
    His new bulb(s) do not turn on by his observation.
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by lhlan View Post
    I’m telling you from first hand experience that you have to clear the code after changing the H7 cornering bulbs to make the car kick on the AFS modules again; with the code present, and as others have stated like the Audi-encyclopedia @Smac770, the code will prevent the car from enabling the AFS modules that control the on/off of the H7 bulbs.
    Just adding new bulbs does nothing for the code stored in the computer.
    °2011 A4 | 6MT
    Oct 21 2022
    Sydney
    My bad. Thanks for pointing out that part: code prevents operations.
    Sent from my Mi 9 SE using Tapatalk
    Aug 06 2012
    Parker, CO
    H7 bulb… with AFS? We should be talking D3S bulbs.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Jul 16 2018
    Atlanta
    That was my initial thought as well, is this misuse of the halogen term. But as it turns out, the static cornering lamp is the same H7 12V 55W halogen bulb as used for the low beam and the high beam bulbs in the halogen headlamps (ie, it's actually the same p/n). The turn signal bulb is a traditional incandescent bulb.
    Oct 23 2014
    Buffalo, NY
    No problem, it’s an understandable thought that once you change the bulb the car should be intelligent enough to realize being that it can check bulb out errors. I learned this the hard way and that’s why I could make certain statements.
    Quote Originally Posted by treginginco View Post
    Yeah the AFS feature is the bi-xenon D3S lights moving left and right as the position of the nose of the car changes per the steering wheel input.
    AFS headlights also give the car the cornering bulbs that are short-sightedly (IMO) halogen H7 bulbs that only turn on under specific conditions such as speeds under 15 or 20 MPH IIRC. Unfortunately rumor has it that swapping to LEDs will cause the AFS modules to burn out; I’m not sure of this but do use a Philips extreme white vision H7 halogen whatevers instead, and I’ll say the hue isn’t my favorite.
    Again Smac770 is correct and for reference, below is an image of my headlights during my projector swap where you can see the halogen blue bulbs for the cornering lights. The projectors sit in a motorized bracket that are also controlled by the AFS module and move the projectors right to left.
    °2011 A4 | 6MT
    Junior Member Two Rings
    Aug 10 2018
    North Jersey
    can someone confirm: what is the proper way to clear the code using odb11 after replacing the H7 cornering bulb? thanks :)
    Jul 16 2018
    Atlanta
    Apparently there's a trash can icon in the bottom right when looking at the faults list under a control module. Press that.
    Junior Member One Ring
    Aug 20 2020
    Quote Originally Posted by opsx View Post
    I just changed my passenger side cornering light since it was burnt, vhanged driver side too while at it, i cant clear the code too with my obd ( blue driver) , still have the "headlight range control: headlight converter active: range reduced" and right after the "audi adaptive light defective" error codes but cant clear them
    Aug 20 2020
    Quote Originally Posted by Stylemaster View Post
    Ive tried with obd2/obdeleven still when i clear the code it comes back .5 seconds later can the dealer clear that code or maybe its a wire that broke inside the headlight?
    Jul 16 2018
    Atlanta
    If the code won't clear, then the condition triggering it is likely still present. If you have OBDeleven, do a scan, find the history log, post the history log so the complete story of the whatever is wrong can be seen (well, as much as OBDeleven can show; it's no VCDS).
    It could be anything related to whatever the code is talking about. The cryptic text from the blue driver implies this is about the range control, not the lighting elements.
