Results 1 to 16 of 16
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    Fake cabin exhaust added, yes or no?
    While i've owned my share of M cars that I've removed the added fake exhaust sound pumped through the cabin at times. Wondering if Audi has done similar with these C8 Rs6/Rs7's?
    Jul 21 2015
    Not that I can tell. There is a solid group of us (pre performance model) looking for ways to get a more pronounced exhaust note as the cabin is very well insulated.
    I hated it in F80.
    Junior Member Two Rings
    Aug 16 2023
    Pa
    Yes they do pump fake exhaust sound into the cabin. It can be disabled via VCDS or OBEleven.
    Search for "Soundaktor".
    May 30 2005
    fl
    have you done this, if how much of a difference did it make?
    Sep 11 2011
    2022 RS7 & 2201 TTRS
    DFW
    I seem to recall a video out there, I will try and find it again, that showed someone with the VCDS hooked up to detail the difference between 10(max volume setting) and 0 (off) for the soundaktor on a C8 RS model. It was not very noticeable on camera nor to him sitting in the car between both settings.
    Previous to this I was under the impression that this model did not have the soundaktor. Have had it before (TTS) and it was very noticeable between drive settings. Remember as well that the Soundaktor uses the windshield to transmit the sound, so it should bypass all the sound insulation near the firewall. I agree the car is still a little too quiet in dynamic mode.
    2022 RS7 & 2021 TTRS
    Retired: Macan S, 2019 RS5, 2020 TTS, 2019 S4, 2017 TT, 2014 A6 TDI, 2014 S4, 2011 A4 Avant, 2011 Audi TT Roadster
    Sep 16 2017
    R8 6MT, RS6
    Flower Mound, TX
    Quote Originally Posted by SK8 View Post
    When configuring RS1 and RS2 modes, there is an option for quiet vs loud (something along that line) for sound. Does this not change the settings on the Soundaktor? Or does it only control the valves being open vs closed?
    2012 Audi R8 V10 6MT| Suzuka Grey| Twin Turbo
    2015 Ferrari 458 Speciale| Rosso Scuderia
    2020 BMW X7| Mineral White
    2023 Audi RS6 Avant| Ultra Blue
    Aug 16 2023
    Pa
    Quote Originally Posted by brad65ford View Post
    I've always been able to hear the fake sound in Audi vehicles and turn it off. To me it makes a difference getting rid of what I know is a manufactured exhaust note.
    If you're looking for some real exhaust notes in the cabin then cutting the two front resonators out and replacing with straight pipes is the answer.
    May 30 2005
    fl
    Would like a low cost solution to removing this. If I’m right it’s the smooth tone I’d like to get rid of.
    Jul 21 2015
    Quote Originally Posted by PunjabiM3 View Post
    In RS1 and RS2 there is a setting for Engine: Quiet / Auto / Present
    Is this the setting for the artificial exhaust note in the car?
    Established Member Two Rings GR8VTen's Avatar
    Feb 19 2021
    Redmond, WA
    The C8 RS6/RS7 doesn't have a Soundakator, those settings are purely to control the exhaust valves. Soundakator sounds are very distinctively fake and Audi primarily uses them to make the V6 engines sound like they have a bit more grunt - We also have an '21 RS5 and it sounds very synthetic, but at least it sounds like it has grunt from the drivers perspective as the device is right ahead of the windscreen, the C8 sadly sounds like a hairdryer in comparison.
    The C8 is so darned packed with sound insulation even with an Akrapovic, the sound within the car is very muted and disappointing - outside of the car is a totally different story, so exhaust upgrades tend to be for the benefit of passersby, not the driver. The Performance model removes 45 lbs of the soundproofing crap to liven the thing up! clearly Audi got the memo.
    2021 RS7 Daytona Gray Pearl Effect
    2021 RS5 Navarro Blue
    Aug 16 2023
    Pa
    Quote Originally Posted by GR8VTen View Post
    The C8 RS7 does come with a Soundakator which is bolted to the firewall to replicate an exhaust sound. It can be turned off via VCDS, ODIS, or OBDeleven under a control module listed as "Structure Borne Sound Actuator". The unit is located under the wiper cowl on the passenger side of the vehicle.
    Eliminating the the two front resonators makes a huge difference in the exhaust note and overrun (bangs and pops), which can definitely be heard within the cabin in sport mode.
    https://www.youtube.com/watch?v=r5UMl032f34
    May 30 2005
    fl
    Seems there is different opinion for if we have fake sound or not lol. All i know is I would unplug the damn thing if I could find it lol
    Anyone have this to test against?
    Established Member Two Rings allenyao09's Avatar
    Aug 18 2021
    21' Audi RS6 Avant, 23' Toyota Supra 3.0 MT, 08' Mitsubishi Evo X GSR
    damn, this sounds exactly like the C8 RS6/RS7
    2024 Lotus Emira FE 3.5 MT Atlantis Blue
    2023 Toyota GR Supra 3.0 MT Nitro Yellow (gone)
    2021 Audi RS6 Avant Glacier White
    2008 Mitsubishi Lancer Evo X GSR Octane Blue (gone)
    Aug 06 2008
    San Diego
    I didn't think that the C8 RS6/7 had a sounds actor but looking at an auto scan with my HEX-NET of my 2021 RS7 I do see it listed in the module list....
    Here is the list of modules from my scan.
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1B-Active Steering -- Status: OK 0000
    32-Differential Locks -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    74-Chassis Control -- Status: OK 0000
    75-Telematics -- Status: OK 0000
    81-Gear Shift -- Status: OK 0000
    82-Head Up Display -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    C4-DC/DC Converter -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CB-Rear Axle Steering -- Status: OK 0000
    CC-Starter-Generator -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    DB-Frt Corner Rdar 1 -- Status: OK 0000
    DC-Frt Corner Rdar 2 -- Status: OK 0000
    DE-Charger 1 for mobile dev -- Status: OK 0000
    ::2004.5 Stonehenge Gray Passat ::2006 United Gray MKV GTI 6MT::2000 Nogaro Blue S4 6MT::2005.5 Moro Blue S4 6MT::2010 Ibis A4 2.0TQ 6MT ::2017 Scuba A4 P+ Tech Sport 19" :: 2019 Tesla P Model 3 :: 2014 Ibis RS7 ::
    Current:
    ::2001 Nogaro Blue S4 :: 2012 Ibis R8 v10 Gated :: 2021 Nardo RS7 ::
    May 30 2005
    fl
    anyone try removing it and trying on with rs2 mode on to hear of there is a difference?
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    I'm not sure about current models but it's very noticeable when it's on versus off. On my C7 S6 that was one of the first things I did with Vag Com was turn the fake engine noise off.
