This is to confirm that Geba water pumps no longer have cast aluminum impellers with knobby interiors. They now have impellers made from three pieces of sheet steel stamped and welded together to closely approximate the plastic factory impeller.
This seems as good as Hepu's brass impeller and much better than Graf's stamped one. It's certainly less draggy than Geba's old #10-grit sandpaper casting and, according to Gunnar, Geba's bearings and seals are reliable. It is
identical to the Meyle HD pump, which has to be re-badged Geba, and Meyle gives it an un-matched 4-year warranty, such is their confidence in Geba's product.
Thanks Gunnar for adding Geba to the discussion. I hadn't noticed this brand.
BTW, the INA branded belt that comes in INA's TB kits is made in Poland, and INA is a respected brand. The Continental OEM belt is made in Romania, which has me thinking... One former Soviet bloc dungeon. Another... tuh-MAY-tuh, tuh-MAH-tuh...
Combining INA's 530 0546 10 TB kit with Geba's pump gets you a COMPLETE "Litens" upgrade kit, including a metal impeller pump that's probably excellent, for chump change compared to going all-Genuine, with more than enough left over to get a pro grade
UView 550000 Airlift cooling system leak tester & vacuum filler. Both brands have good testimonials from expert 'ziners.
