B8 S4 dsg: So the vibration occurs when the car is in reverse or drive as I release the brakes and let the car roll, vibrates and shakes like as if i have a dent or wheel bent. Thats how it feels like. But when the speed increases, the vibration is less noticeable. Assuming it was a bad engine mount, today, I had the engine mounts replaced with 034 street mounts. Vibration decreased by about 50% but still exists. Dsg sounds a little clunky. Can this be the dsg or maybe the drive shaft bearing carrier? Trans mount and the metal insert replaced with 034 prior to engine mount. Car is stage 2 IE and trans tune. Any ideas?
