Thread: GFB DV+
    Veteran Member Three Rings mrmeth90's Avatar
    Jun 29 2007
    Miami
    GFB DV+
    Anyone running upgraded diverter valves on their SQ5? I saw that GFB makes one now for our platform. I’ve used for my previous VAG rides. Curious on thoughts. Currently stage 2 B9 93octane.
    Thanks.
    https://www.moddedeuros.com/products...er-valve-t9380
    2008 A4 2.0tQ Phantom Black Titanium-APR Stage 2+ --AWE Quad Tip Black Diamond Exhaust--GSG FMIC--GSG CAI--Labree HFC--APR Snub--AWE Boost Gauge--Xenon Retrofit/Blacked out housing/CC Mod--Painted front and rear Reflectors--Lamin-X Tails--ZiZa Pure Yellow Fogs--H&R Coilovers--H&R Rear Sway Bar--
    Next Mods:
    APR HPFP, LED Taillights, BBK (not sure brembo or stoptech) Carbon Fiber Trim, Recaro Seats...
    Veteran Member Three Rings sandman00's Avatar
    Jan 02 2015
    queens
    Hey bud, I did try the one from Forge for a while but I wanted something that was more reliable and switched to Turbo Smart diverter valve. A much better option I have used it stage 2 and stage 3 plus. Excellent unit throws no codes.
    https://www.turbosmart.com/product/k...umb-back-vr13/
    Mar 10 2021
    MA
    What kind of benefits are you seeing running these day to day?
    2022 SQ5
    CTS Intercooler, Downpipe
    Jackal / M2 Full custom ECU and TCU
    Diamond Audio Subwoofer + 20'' LightBar
    Custom PCV system + Mishimoto catch can
    ABT HAS, ECS Skid Plate, Roc Euro Intake, DashCam
    034 Trans Insert, Turbo inlet, Sway Bars, Strut Brace, HPFP
    Chrome Delete + CF Mirror Caps / Wide Angle Mirrors, Mud flaps
    Senior Member Two Rings NRigs's Avatar
    May 21 2015
    Ma
    Quote Originally Posted by Local View Post
    They supposedly keep boost better between shifts. GFB usually has a little bit of data to show the differences in boost pressure between a stock and their DV+ option but it doesn't look like they have any data linked to this one for the B9 platform.
    The only thing you will really notice is the different sound it makes when you let off the throttle under a bit of boost. You won't feel any "benefit" it may offer. I am sure the stock DVs on these cars are pretty solid and it doesn't seem like anyone with high mile 2018/2019 models have reported any failures. On stock turbo, the stock unit is totally fine. You may get more out of the upgraded DV on an upgraded turbo.
    2020 SQ5 Prestige | IE Stage 1 | BMC Air Filter | 034 Transmission Insert
    Gone:
    2011 335xi | Custom Tune | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
    2014 A4 | CTS K04 l Euro Code HFIP l TR11 l 034 Mounts & Inserts l ECS Luft-Technik l DV+ l LED Light Swap l R8 Coils l NGK plugs l RS4 Grille l Niche Targas M129 l Continental DWS 06 l CR-15
    Junior Member Two Rings meshgiath's Avatar
    Jul 20 2009
    Previous ride: 2007 Light Silver Metallic A3 2.0t - k04
    Western TN
    I can't speak to the 3.0 B9 GFBs, but I swapped to a GFB DV+ on my 2.0t A3 and could tell quite a bit of difference when I ran a k04. Power application felt more smooth and less surge-y and there seemed to be more oomph at the beginning of each gear.
    DD: 2018 SQ5 | Daytona Grey over Red | 034 Stg1 ECU Stg2 TCU | IE Inlet and Intake
    FS: 2007 A3 2.0t | DSG | BSH 27mm Solid RSB | EvoMS Intake | 42DD 3" DP Res/Cat (dd) | 18" Caleras | APR HPFP | APR Tuned HPA k04
