Results 1 to 3 of 3
    Junior Member One Ring
    Jul 09 2022
    Oakland CA/Rochester NY
    2018 B9 S5 MMI Buttons Not Working Caused by Wireless Carplay Module U10E400 U112100
    TLDR; After using an amazon wireless carplay module all of the switches for my MMI don't work ;(
    I have been having issues with my MMI since I used a wireless apple carplay module.
    Link to google drive with all info: Google Drive Folder
    What Happened:
    I bought my 2018 B9 S5 on Thursday August 24th. On August 26th I plugged in the Carlinkit 3.0 wireless carplay module and began using it. Initially, I had no issues using this module to control the Apple carplay, it connected quickly and I had no issues using the rest of the MMI.
    On August 30th, as shown in the below error history from VCDS, the issues began.
    I had the wireless carplay module plugged in, iPhone connected, car on, and Apple carplay opened when I unplugged the module. Immediately after, the ‘no mobile device connected’ menu came up in the MMI. At the same time, all of the buttons in front of the shifter ie the main MMI wheel, preset buttons, etc. stopped working.
    Current situation:
    The MMI screen still displays correctly when I am changing the lumbar support, side bolstering etc. as well as the drive mode selection, but again, none of the buttons in front of the shifter that would typically allow you to change the radio, interact with apple carplay or change car settings do not work in any shape or form and do not light up.
    I am still able to use apple carplay by plugging in the same wireless carplay module and using voice controls, as well as steering wheel controls. The carplay does display correctly on the MMI screen. The steering wheel controls to adjust volume and go forward and back tracks work with no problem and it still responds to voice commands ie ‘start directions to home’ and ‘open waze’.
    I have tried the MMI Reset that one can usually do by holding the two silver buttons forward and pressing the main dial down and releasing at the same time but absolutely nothing happens.
    What can be done:
    I really want to believe this is a software issue that can be somehow solved with VCDS but I am increasingly worried that a module associated with the MMI and how it interfaces with the controls and the rest of the car is physically damaged (ie a transistor or something) and needs replacement. Ultimately I would love to be able to DIY this problem and am willing to give it my all but I am not super experienced with VCDS and this is the first car that I have owned that's newer than 2003 so I am hesitant.
    What I am looking for:
    Really any input at all on what I should try to solve this either with VCDS, physically replacing modules or doing much of anything else.
    Here is a screenshot of the errors that I believe to be related in VCDS:
    Imgur Link if broken: https://imgur.com/a/fQUmvrZ
    Here is the full VCDS Log:
    VCDS
    Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: Release 23.3.0(x64) Data version: 20230228 DS346.1
    www.Ross-Tech.com
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Sunday,03,September,2023,23:14:20:23169
    VIN: WAUB4CF58JA018532 License Plate:
    Mileage: 63288km-39325mi Repair Order:
    Chassis Type: F5-AU49 (8W8)
    Scan: 01 02 03 08 09 15 16 17 19 29 32 36 39 3C 42 44 46 47 52 5F
    6C 6D 74 81 A5 A9 BB BC CA CF D6 D7
    VIN: WAUB4CF58JA018532 Mileage: 63288km-39325miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    29-Left Light -- Status: OK 0000
    32-Differential Locks -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    39-Right Light -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    74-Chassis Control -- Status: Malfunction 0010
    81-Gear Shift -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    VCDS
    Self-Diagnosis Log
    Page 2
    Address 01: Engine (J623-CWGD) Labels:. 07K-907-309-V1.clb
    Part No SW: 8W0 907 559 H HW: 06M 907 309 D
    Component: V6 3.0l TFSI H21 0009
    Revision: B2H21000 CVN: A15072C0
    Coding: 1A2A00322326010E34280000000000000000000000000000
    Shop #: WSC 82976 802 690857
    ASAM Dataset: EV_ECM30TFS0118W0907559H 001010
    ROD: EV_ECM30TFS0118W0907559H.rod
    VCID: 4ACD73848C3AA14A917-801E
    VINID: 9D195211358521A44004814308C05C86AD
    1 Fault Found:
    4718 - No Communication with Transmission Control Module
    U0101 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 62694 km
    Date: 2023.08.30
    Time: 21:26:59
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 46 °C
    Intake air temperature: 33 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 12.900 V
    Unlearning counter according OBD: 20
    Com st X Set1 Val1-Bits 0-7: 0
    Com st X Set1 Val2-Bits 0-7: 0
    Com st X Set1 Val3-Bits 0-7: 0
    Com st X Set1 Val4-Bits 0-7: 0
    Com st X Set1 Val5-Bits 0-7: 0
    Com st X Set1 Val6-Bits 0-7: 0
    Com st X Set1 Val7-Bits 0-7: 1
    Com st X Set1 Val7-Bits 0-7: 0
    Readiness: 0000 0000
    VCDS
    Self-Diagnosis Log
    Page 4
    Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
    Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
    Component: ESP9 Plus H10 0766
    Dataset Number: 8W2909504D 0007 CVN: 18E61C2C
    Coding: 1CAA149A30A30A9E11A34894407F5292E4259A38280C508812 024A4927A459
    Shop #: WSC 06334 790 00001
    ASAM Dataset: EV_ESP9BOSCHCMP 002013
    ROD: EV_ESP9BOSCHCMP_004_AU49.rod
    VCID: 4DC778987D54B672B45-8018
    3 Faults Found:
    12648705 - No Communication with Transmission Control Module
    U0101 00 [032] - -
    [ComScl:_Signal_Group_SG_Getriebe_11-_Timeout_error]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Mileage: 62694 km
    Date: 2023.08.30
    Time: 21:26:59
    82 00 80 00 C2 00 00 00 00 00
    Unlearning counter according OBD-OBD unlearning counter: 14
    12648704 - No Communication with Transmission Control Module
    U0101 00 [032] - -
    [ComScl:_Signal_Group_SG_Getriebe_13-_Timeout_error]
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Mileage: 62694 km
    Date: 2023.08.30
    Time: 21:26:59
    473088 - Databus
    U1121 00 [040] - Missing Message
    [ComScl:_Signal_Group_SG_Getriebe_15-_Timeout_error]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Mileage: 62694 km
    Date: 2023.08.30
    VCDS
    Self-Diagnosis Log
    Page 5
    Address 08: Auto HVAC (E87) Labels:* Redir Fail!
    Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
    Component: Klima Zone 3 H55 0205
    Coding: 1608050D5548000D1002010088000000000000000000000000 0000000000
    Shop #: WSC 06335 790 00001
    ASAM Dataset: EV_AirCondiBHTCAU491 001013
    ROD: EV_AirCondiBHTCAU491.rod
    VCID: 44D15DBCAE1E773A6BB-8010
    Fresh air blower control module (front):
    Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
    Component: J126 FLuftV H08 0003
    Serial number: 00000000000001620887
    Humidity sensor: exterior:
    Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
    Component: AQ_Hum_Sensor H01 0006
    Serial number: 4DE05FA880PAG0MUFU02
    Rear air conditioning block 1:
    Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
    Component: E265 Kli Fond H40 0080
    No fault code found.
    VCDS
    Self-Diagnosis Log
    Page 6
    Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
    Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
    Component: BCM1 MLBevo H13 0267
    Dataset Number: 8W2909514D 0032
    Coding: 07500363E0081CCD050D8715182C1CB9110B3D040000000000 000000200016010A690122025705
    Shop #: WSC 56257 004 1048576
    ASAM Dataset: EV_BCM1BOSCHAU736 018006
    ROD: EV_BCM1BOSCHAU736_018_AU49.rod
    VCID: 025D9BA4F48AB90A197-8056
    Wiper motor control module:
    Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
    Component: 494 LL 080517 036 0471
    Serial number: 00000001705020305202
    Coding: 5FC7F7
    Rain/Light Recognition Sensor:
    Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
    Component: G397_RLFSS H06 0002
    Serial number: 20467930X81A955555A0
    Coding: 02005D
    Light switch:
    Subsystem 3 - Part No SW: 4M0 941 531 S HW: 4M0 941 531 S
    Component: E1 - LDS H06 0008
    Serial number: 08 03 2017 00822058
    Garage door opener control module:
    Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
    Component: USHL5 H08 0050
    Serial number: 0000009600363Z01ZE02
    Coding: 350000
    Garage door opener control head:
    Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
    Component: GTO BF H01 0010
    Serial number: 20170508140856 00652
    Automatic dimming interior mirror:
    Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
    Component: Y7_Innenspieg H01 0002
    Serial number: GX1CE129031723611722
    Coding: 010000
    Interior Light Module:
    Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
    Component: J528-Dachele H14 0130
    Serial number: B00397676
    Control head for driving and comfort functions:
    Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
    VCDS
    Self-Diagnosis Log
    Page 7
    Serial number: 2617000035984004
    Coding: 000000
    Valve block 1 in front seat driver side:
    Subsystem 9 - Part No SW: 8W0 907 182 HW: 8W0 907 182
    Component: J873 MKS_FSv H03 0034
    Serial number: 7008174235B171635600
    Coding: BF0500
    Valve block 1 in front seat passenger side:
    Subsystem 10 - Part No SW: 8W0 907 182 HW: 8W0 907 182
    Component: J872 MKS_BFSv H03 0034
    Serial number: 7008174235B171636128
    Coding: B30500
    VCDS
    Self-Diagnosis Log
    Page 8
    Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
    Part No SW: 8W0 959 655 J HW: 8W0 959 655 J
    Component: Airbag10.44 H09 0104
    Serial number: 003US0006KRS Dataset Number: 8W2909602AC 0012
    Coding: BFCCF0C000800000A0000033D24C00000000
    ASAM Dataset: EV_AirbaAU10BPAAU736 005015
    ROD: EV_AirbaAU10BPAAU736_005.rod
    VCID: 50F961EC6A669B9ADF3-8004
    Left seat belt tensioner:
    Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
    Component: BeltPretRevFL 306 2033
    Serial number: 8W0857705G0151R01340
    Coding: 80000D
    Right seat belt tensioner:
    Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
    Component: BeltPretRevFR 306 2033
    Serial number: 8W0857706J0153R01127
    Coding: 80000D
    Seat occupied recognition passenger side:
    Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
    Component: BF-Gewichtss. H11 0022
    Serial number: IBH0000J170007EQPZ08
    Crash sensor for side airbag: driver side:
    Subsystem 4 - Part No SW: ----------- HW: 442 061 905 17
    Component: SideSensor_Df 1E2 0887
    Serial number: 3577Y00B92414143642L
    Coding: 2D2D2D
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 5 - Part No SW: ----------- HW: 442 061 905 17
    Component: SideSensor_Pf 1E2 0887
    Serial number: 3587Y00A52439D21C10X
    Coding: 2D2D2D
    Rear Side Airbag Crash Sensor (on driver's side):
    Subsystem 6 - Part No SW: ----------- HW: 442 0B2 005 17
    Component: SideSensor_Dr 1C7 0148
    Serial number: 3517700A52694CA52125
    Coding: 2D2D2D
    Passenger side rear thorax airbag crash sensor:
    Subsystem 7 - Part No SW: ----------- HW: 442 0B2 005 17
    Component: SideSensor_Pr 1C7 0148
    Serial number: 3527700C12694CA201C9
    Coding: 2D2D2D
    VCDS
    Self-Diagnosis Log
    Page 9
    Subsystem 8 - Part No SW: ----------- HW: 442 0C1 105 17
    Component: FrontSensor_D 1C5 014A
    Serial number: 3557500BD25E5CE3C38+
    Coding: 2D2D2D
    Crash sensor for front airbag: front passenger side:
    Subsystem 9 - Part No SW: ----------- HW: 442 0C1 105 17
    Component: FrontSensor_P 1C5 014A
    Serial number: 3567500BD25E5CE4F2D7
    Coding: 2D2D2D
    Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
    Part No SW: 4M0 907 129 GK HW: 4M0 907 129 GK
    Component: Lenks.Modul H11 0009
    ASAM Dataset: EV_SMLSKLOAU736 006008
    ROD: EV_SMLSKLOAU736_006.rod
    VCID: 7F5B12508778D4E2769-802A
    Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
    Part No SW: 8W5 920 890 D HW: 8W5 920 890 D
    Component: FBenUSA H18 0371
    Coding: 09EF49CB38A8CF05022369601800000008000000
    ASAM Dataset: EV_DashBoardAU736 001027
    ROD: EV_DashBoardAU736_AU49.rod
    1 Fault Found:
    16777072 - Databus
    U1121 00 [008] - Missing Message
    [WBA_03 communication error can_error_timeout]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 62694 km
    Date: 2023.08.30
    Time: 21:33:52
    VCDS
    Self-Diagnosis Log
    Page 10
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 8W8 907 468 E HW: 8W8 907 468 E
    Component: Gateway H42 0116
    Revision: 6D020002 Serial number: 0286D788617608 Dataset Number: 8W2909515C 0042
    Coding: 030100010000064054070000005900106C9800079000000001 50000000000000
    GVL: 01503C500800000040DC08000002C800110C00000000000000 00000000000000
    ASAM Dataset: EV_CGateCONTIAU491 003092
    ROD: EV_CGateCONTIAU491_003_AU49.rod
    VCID: 4EC57F9470528D6ACDF-801A
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H
    Component: J453 MFL H04 0002
    Serial number: 20170522170530 01915
    Battery Monitoring Control Module:
    Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
    Component: J367-BDMHella H10 9070
    Serial number: 0249094204
    Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
    Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
    Component: LCM_MLBevoH05 0024
    Dataset Number: 8W2909519B 0003
    ASAM Dataset: EV_LCMLeftHELLAAU736 001012
    ROD: EV_LCMLeftHELLAAU736_VW48.rod
    VCID: 78A9F94CA256E3DA373-802C
    Address 32: Differential Locks (J187) Labels: None
    Part No SW: 8W0 907 163 HW: 8W0 907 163
    Component: QSP QCU Gen2 H07 0040
    Revision: 5WK12700 Serial number: 605721109250807
    Coding: 0001
    ASAM Dataset: EV_TVDCQSP22 001007
    ROD: EV_TVDCQSP22.rod
    VCID: 79AFFC48995CFAD248D-802C
    VCDS
    Self-Diagnosis Log
    Page 11
    Address 36: Seat Mem. Drvr (J136) Labels:* None
    Part No SW: 4M1 959 760 HW: 4M1 959 760
    Component: MEM-FS 008 0031
    Serial number: 00000259933597 Dataset Number: 8W2909856B 0013
    Coding: 005C1B000000B0010000010101010000000000000000000000 000000000000
    ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
    ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
    VCID: 76B5F774A84295AA25F-8022
    Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
    Dataset Number: 8W2909520B 0003
    ASAM Dataset: EV_LCMRightHELLAAU736 001012
    Address 3C: Lane Change (J769) Labels:* None
    Part No SW: 4M0 907 566 D HW: 4M0 907 566
    Component: MRR1Rear H18 0410
    Revision: -------- Dataset Number: 8W2909535B 0010
    Coding: 0E8002
    ASAM Dataset: EV_RearRadarS1BoschAU736 001022
    ROD: EV_RearRadarS1BoschAU736.rod
    VCID: 36353774E8C2D5AAE5F-8062
    VCDS
    Self-Diagnosis Log
    Page 12
    Address 42: Door Elect, Driver (J386) Labels:* None
    Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
    Component: TSG FS 005 0125
    Serial number: 0000261231469 Dataset Number: 8W2909872B 0020
    Coding: 005F5B625E001080000104B2
    ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
    ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
    VCID: 43D35EA0AB107002521-8016
    1 Fault Found:
    196662 - Motor for Window Regulator
    B1487 01 [008] - Electrical Failure
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 204
    Mileage: 63156 km
    Date: 2023.09.02
    Time: 23:11:49
    Address 44: Steering Assist (J500) Labels:* None
    Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
    Component: EPS_MLBEVO_ZF H08 0409
    Dataset Number: 8W2909852N 0026
    Coding: 09000380008000
    ASAM Dataset: EV_EPSZFAU49X 003018
    ROD: EV_EPSZFAU49X_003.rod
    VCID: 41DF54A8B10C621240D-8014
    VCDS
    Self-Diagnosis Log
    Page 13
    Address 46: Central Conv. (J393) Labels:* None
    Part No SW: 8W0 907 064 DC HW: 8W0 907 064 DC
    Component: BCM2 MLBevo 019 0366
    Dataset Number: 8W2909501D 0031
    Coding: 013400004F3100C0650B80006E01080033004000810022502F 0400000F04803F001E0001000000
    ASAM Dataset: EV_BCM2HellaAU736 013013
    ROD: EV_BCM2HellaAU736_013_AU49.rod
    VCID: 005991ACFA86AB1A0F3-8054
    Anti-theft alarm system sensor:
    Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0316
    Serial number: 000000000ZY171244GTK
    Alarm horn:
    Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
    Component: Sirene, DWA 005 0314
    Serial number: 00000000000069700042
    Rear lid opener control module:
    Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
    Component: GEB.F.Heckoef H16 0904
    Serial number: >1103312
    Address 47: Sound System (J525) Labels:* None
    Part No SW: 8W0 035 465 HW: 8W0 035 465
    Component: MIB2_amp_P_B9 H11 0420
    Revision: 00000001 Serial number: AUZ8ZAHJA01VTN0 Dataset Number: 8W2909510A 0007
    Coding: 0194030800AFAAAFAA0000010000
    ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
    ROD: EV_AMPMst16C2Gen2ALPI.rod
    VCDS
    Self-Diagnosis Log
    Page 14
    Address 52: Door Elect, Pass. (J387) Labels:* None
    Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
    Component: TSG BFS 005 0125
    Serial number: 0000261373083 Dataset Number: 8W2909873B 0020
    Coding: 005F5B225E001080000104B0
    ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
    ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
    VCID: 42DD5BA4B40A790A597-8016
    VCDS
    Self-Diagnosis Log
    Page 15
    Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
    Part No SW: 8W5 035 880 A HW: 8W5 035 880
    Component: MU-P-LNS-US 034 1118
    Serial number: A798F0HB034056 Dataset Number: 8W2909545H 0035
    Coding: 019453020000000013220002041A00102F0012E501700904FE
    ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
    ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
    VCID: 3D272858CDF406F2245-8068
    Data carrier:
    Subsystem 1 - Part No SW: V03 959 803 AF HW: -----------
    Component: NAR 2020 --- 0076
    Serial number: --------------------
    Multimedia System 1:
    Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
    Component: DU High AU49x H32 0160
    Serial number: TPO00124041700820487
    Compact disc data bank:
    Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote2 --- 3012
    1 Fault Found:
    6664 - No Communications with Control Head for Multimedia
    U10E4 00 [009] - -
    [Operating unit: no signal/communication]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 156
    Mileage: 62793 km
    Date: 2023.09.01
    Time: 18:16:46
    Voltage terminal 30: 14.4 V
    VCDS
    Self-Diagnosis Log
    Page 16
    Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
    Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
    Component: RVC Compact H12 0250
    Dataset Number: 8W2909460C 0011
    Coding: 0294030102002001400040
    ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
    ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
    VCID: 33330E60FBB0C082C21-8066
    Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
    Part No SW: 8W8 959 107 B HW: 8W8 959 107
    Component: HDSG-Modul H13 0161
    Revision: -------- Serial number: 31408389000000 Dataset Number: 8W2909541B 0004
    Coding: 0630
    ASAM Dataset: EV_DeckLidCONTIAU736 001014
    ROD: EV_DeckLidCONTIAU736_AU37.rod
    VCID: 48C9498C9236535A873-801C
    VCDS
    Self-Diagnosis Log
    Page 17
    Address 74: Chassis Control (J775) Labels:* None
    Part No SW: 8W0 907 777 H HW: 8W0 907 777 C
    Component: Fahrwerk-SG H35 1214
    Serial number: 0406170120 Dataset Number: 8W2909576D 0002
    Coding: 1460484958
    ASAM Dataset: EV_ChassContrContiAU426 001003
    ROD: EV_ChassContrContiAU426.rod
    VCID: 4CC1759C864EBF7AA3B-8018
    3 Faults Found:
    3407876 - Databus
    U1123 00 [008] - Received Error Message
    [Internal_communication_error_ESP_Systemstatus]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 62694 km
    Date: 2023.08.30
    Time: 21:33:53
    4456458 - Implausible Data Received from ABS Control Module
    U0415 00 [008] - -
    [Function_restriction_due_to_communication_interrup tion_EspOverSteer]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 62694 km
    Date: 2023.08.30
    Time: 21:33:53
    4456531 - Implausible Data Received from ABS Control Module
    U0415 00 [008] - -
    [Function_restriction_due_to_communication_interrup tion_EspUnderSteer]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 62694 km
    Date: 2023.08.30
    Time: 21:33:53
    VCDS
    Self-Diagnosis Log
    Page 18
    Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
    Part No SW: 8W1 713 041 F HW: 4M1 713 041 F
    Component: GSM-LL H09 0077
    Revision: 0L0D5012 Serial number: 20170530002484
    ASAM Dataset: EV_GSMWaehlZFAU736 001017
    ROD: EV_GSMWaehlZFAU736_AU49.rod
    Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
    Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
    Component: BVS H15 0050
    Dataset Number: 8W2909466C 0019
    Coding: 0404090300000204022023A2AD0000FC00F0C020C000
    ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
    ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    VCID: 40D951ACBA066B1A4F3-8014
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 8W0 907 159 E HW: 4H0 907 159 A
    Component: SAS-GEN 2 H07 0007
    Serial number: 170527200014
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    Address BB: Door Rear Drv (J388) Labels:* None
    Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
    Component: TSG HFS 005 0125
    Serial number: 0000260941100 Dataset Number: 8W2909897B 0019
    Coding: 000F5B2200001080400000A0
    ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
    ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
    VCID: 45D740B8A5244E327C5-8010
    VCDS
    Self-Diagnosis Log
    Page 19
    Address BC: Door Rear Pass (J389) Labels:* None
    Component: TSG HBFS 005 0125
    Serial number: 0000260941332 Dataset Number: 8W2909896B 0019
    ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
    ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
    Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
    Part No SW: 4M0 907 594 J HW: 4M0 907 594
    Component: SAD_STG_1 014 0005
    Dataset Number: 8W2909469B 0007
    Coding: 228000049301
    ASAM Dataset: EV_SunRoofCONTIAU736 006008
    ROD: EV_SunRoofCONTIAU736_006.rod
    Address CF: Lane Chge Asst 2 (J770) Labels: None
    Part No SW: 4M0 907 590 D HW: 4M0 907 590
    Revision: --------
    Coding: 0E8002
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_RearRadarS2BoschAU736 001022
    ROD: EV_RearRadarS2BoschAU736.rod
    Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
    Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
    Component: LED1L H09 0008
    Dataset Number: 8W2909471A 0008
    ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
    ROD: EV_LEDModLeftMELCOAU736_VW37.rod
    VCID: 176BDAF08F080CA2DE9-8042
    VCDS
    Self-Diagnosis Log
    Sunday,03,September,2023,23:14:21:23169
    Page 20
    Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
    Component: LED1R H09 0008
    Dataset Number: 8W2909472A 0008
    ASAM Dataset: EV_LEDModRightMELCOAU736 001004
    End----------(Elapsed Time: 02:22, VBatt start/end: 12.4V/12.4V)-----------
    Established Member Two Rings zztroyzz's Avatar
    Jun 27 2010
    Ontario, Canada
    Probably not helpful but just in case you didn’t do the reset button sequence correctly you can see it done here:
    https://youtu.be/_KFgWictfSo?si=cYbVXAnlhZxpMeWK
    I don’t actually know if holding it down works when you need a quick press.
    I’ve had some wonky behaviour with my CarPlay module but unplugging it has always fixed it.
    I wonder if disconnecting the battery for a few minutes would force it to reset.
    Junior Member One Ring Reason92's Avatar
    Apr 05 2023
    2021 TTRS, 2024 Q5
    Austin, TX USA
    Have you had any luck resolving?
    I’ve been using my Carlinkit for maybe 6 months. Occasionally he GPS would freeze, I’d unplug the module and plug it back in, and all would be fine.
    About a week ago I went back to wired, and now the gestures on my MMI wheel no longer work. I thought it might be a glitch, but after a few days decided to research…. Everything else seems to work fine.
    2021 TTRS
    2024 Q5
    Gone: 2019 S5 SB
