2002 Audi B6 A4 Sedan AWD with the Automatic. About 266k miles on it.
In January, the temperature dropped to -16F one night with a windchill of -40F. The next morning, when I started the car, it started to overheat which was odd. Turned the car off and then gave it another 24 hours. The following day, it was quite a bit warmer, car came up to operating temperature and did not overheat but very strangely, when the car was done being driven and turned off (key out of ignition) the fans would run for 10-15 minutes and vary speeds (not racing constantly but would instead run very slow for about a minute, then race for about 10 seconds, then medium speed for 2 minutes, etc). This kills the battery every time.
I plugged in my VCDS and pulled codes with absolutely nothing remarkable showing for the cooling system, or engine management overall.
Given the ease of changing out the fan relay (located under the ECU under the hood) and how common the fans running after car is off issue is resolved with this part, I did that just to see if that was the simple fix. It was not. The fans still run after the car is off and the battery still dies.
I've done some more tests and here are some other observations that I have made:
1. If you pull fuse #9 (Radiator Fans) when the car is off and fans are still running, they CONTINUE to run.
2. If you pull fuse #29 (Engine Management) when the car is off and fans are still running, they STOP. Plugging the fuse back in does NOT cause the fans to run again until the car is started. The unfortunate side effect of this is that is causes the EPC light to come on.
3. If you disconnect the radiator fan power supply harness behind the driver's side headlight while the fans are running and car is off, the fans stop. Reconnecting this harness will cause the fans to start again.
4. If you disconnect the ECU (main harness going into the ECU) while the fans are running and car is off, the fans stop. Reconnecting it will not cause the fans to start again until the car is started.
5. If you pull the fan relay (under the ECU) while the fans are running/car is off, the fans stop. Reconnecting the relay will NOT cause the fans to run again until the car is started.
I checked a variety of measuring blocks via VCDS to see if something weird was going on with the ECU/Fans/Thermostat but both the Radiator Outlet Temperature Sensor and Coolant Temperature Sensor seem to report valid values through out a drive cycle, starting with a cold vehicle. Thermostat duty cycle seems to be reasonable based on the given engine temps. Air Conditioning on/off has no effect on any of the observed behaviors.
It's an old car, without a doubt, but I would really like to diagnose this and get it fixed. I'm never a fan of just firing the parts cannon at things so if anyone has any thoughts on what the issue might be I'd love to hear some input. I can drop some drive logs in the thread if that is helpful as well, just let me know what measuring blocks you want to see.
