Brand new 12 inch brushless motor fans x 2 with relays and digital controller. Can also use PWM from ECU if you know the details. Excellent quality and high CFM. Link to product website below. I choose to go with a larger single fan but had purchased these too early in my planning and cant return. Never installed. These are "Pull" oriented fans. Total cost of kit is about $840. Selling the whole kit for $350 + shipping. Good Product support from owner John if you have questions. They can also make custom aluminum fan shrouds for the kit.
https://deltapag.com/products/12-brushless-fan-kit
12" Fan with 2,100 CFM
14 amp @ 13vdc with Soft-Start
100% Waterproof, Sealed and encapsulated motor and components.
8-28vdc, No changes needed. Ask us about our 48v ECM.
Variable speed with our Digital Controller or +PWM
High static pressure capable to pull through very dense cooling stack.
Kits with digital controller include 12" Brushless Fan, 1 ECM, 3ft power harness with single relay/fuse module, sensor & 3ft waterproof controller harness
