Originally Posted by
Valpo A7
Make sure to jack up the suspension to ride height before torquing the big ass bolt. It’s actually a replace me torque to yield bolt but when I did mine I torqued it plus a bit more rather than the portion of extra turn called for in the book. I did not replace mine and it has not broke.
Awesome, I'm glad you responded because....
I just got to that part and I was about to ask, and you answered my question. I found
this thread, and it said it was a bolt which needs replacing.... YAY! Good to know you reused yours. That thing was a beeyotch to get back in and lined up, I finally did, and I popped my upper arm off to wiggle more (turns out I just needed to compress my spring more) either way, it is off to the alignment shop tomorrow. As always, if/when I need to change the other side, I know all the tricks. I couldn't find the bolt in a quick search, but it won't be that hard to replace. Looks like torque is 120nm plus 360 degrees.
I obviously couldn't jam my torque wrench in there to torque the bearing down right either, so I just tightened it with the 3/8 drive wrench I could stick back there and put a couple of ugga-duggas on them and hope it will be ok (the bolts did come with my bearing so I did replace those).
Would anyone know the torque for that middle beam? I think it is called the tie arm, but I can't find anything.
