Results 1 to 6 of 6
    Junior Member Two Rings
    Jun 24 2023
    2021 Toyota supra
    Columbia, MD
    C8 RS6 - inexpensive exhausts and intakes that people may not know about
    I'm curious if anyone has used any cheaper options of exhausts or intakes from companies that may not be in the limelight.
    I'm looking at intakes and exhausts, but I'm only seeing a couple options.
    Mainly recommendations are welcome
    Instagram @camazotmkv
    Established Member Two Rings allenyao09's Avatar
    Aug 18 2021
    21' Audi RS6 Avant, 23' Toyota Supra 3.0 MT, 08' Mitsubishi Evo X GSR
    Not many options are available to the C8 RS6 unfortunately and most of them are expensive.
    For the exhaust the cheapest option would be a resonator delete (either replace the resonator with straight pipes or simply cut them off).
    And for the intake, a high flow filter might be your best bet. Other intake upgrades all cost thousands.
    2024 Lotus Emira FE 3.5 MT Atlantis Blue
    2023 Toyota GR Supra 3.0 MT Nitro Yellow (gone)
    2021 Audi RS6 Avant Glacier White
    2008 Mitsubishi Lancer Evo X GSR Octane Blue (gone)
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    Try the RS6/RS7 form, here is two threads I created since I too hear you.
    https://www.audizine.com/forum/showt...to-distributor
    https://www.audizine.com/forum/showt...k-air-box-mods
    Jun 24 2023
    2021 Toyota supra
    Columbia, MD
    Definitely Great options on the exhaust...I was actually looking into the resonator and muffler delete "cut off"
    - - - Updated - - -
    Thank you for the threads, will check them out!
    Jun 01 2023
    Fairfield County, CT
    Quote Originally Posted by camazotmkv View Post
    - - - Updated - - -
    I'm not an RS6 owner but I've done this with past cars... Similar to what others have said, you could always purchase a set of reputable mufflers, say Magnaflow, and have an exhaust shop cut out the stock muffler and swap the replacements in. I'd suggest swapping it with clamps v.s. welding to allow you the capability to swap the stock muffler back in if you decide to go another route or sell the car.
    Sep 17 2005
    Fremont, California
    If you're looking for a relatively inexpensive exhaust modification, the 034Motorsport Res-X Resonator Delete may be the perfect option!
    Check out how it sounds here:
    https://www.instagram.com/p/CwS8PQGh0Fz/
    -Sean@034
