Hello everyone,
My wife has a 2012 Audi Q5 (93,500 miles) that has been having a starting issue with a check engine light. Basically, the car either starts roughly and smooths out, or dies one second after startup. Doesn't matter if its hot or cold. Smells like raw fuel often during startup.
Here is what VCDS says:
2 Faults Found:
6128 - Fuel/Air Mixture Cylinder 4
P219F 00 [096] - Unbalanced
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 149070 km
Date: 2023.07.04
Time: 11:39:50
Engine RPM: 706.00 /min
Normed load value: 29.0 %
Vehicle speed: 0 km/h
Coolant temperature: 96 °C
Intake air temperature: 61 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.015 V
Unlearning counter according OBD: 22
Engine speed: actual: 672 /min
MAF_ENVD: 147.07058 mg/stroke
Coolant temperature (unfiltered): 96.0 °C
Engine: operating status: IS
Engine load: 28.906250 %
Vehicle speed: actual: 0 km/h
6213 - Fuel Trim: Bank 2 (Add)
P1139 00 [237] - System too Rich
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Mileage: 145928 km
Date: 2023.06.05
Time: 13:29:08
Engine RPM: 699.00 /min
Normed load value: 31.4 %
Coolant temperature: 92 °C
Intake air temperature: 35 °C
Voltage terminal 30: 14.218 V
Unlearning counter according OBD: 40
MAF_ENVD: 163.41176 mg/stroke
Coolant temperature (unfiltered): 98.3 °C
T_AST_ENVD: 257.00 s
STATE_LS_ENVD[2]: 2
We haven't replaced the spark plugs yet and I am unsure if they have ever been replaced, so I may do that tomorrow. That being said, I'm worried its a leaking fuel injector on cylinder #4. Does anyone have any ideas or pointers?
Thanks for any help,
Dan
