Results 1 to 27 of 27
    Senior Member Two Rings fzr100098's Avatar
    Nov 09 2022
    Charlotte
    8Y Drop in Air Filter
    Not a big fan of K&N, any thoughts on this one?
    https://www.wagner-tuning.com/produc...0001003-2.html
    I believe most of the (small) power gains (near stock boost levels) are in the filter itself. The fancy intakes look cool but doubt they flow alot more air - happy to be proven wrong
    2023 Tango Red RS3
    Jul 13 2018
    Winnipeg, MB, Canada
    Yes they gain a small amount of power because they don't filter as well, meaning more particulate matter entering the combustion chamber. I would stick with the OEM filter.
    Senior Member Two Rings ZTTRS's Avatar
    Jul 26 2018
    TEXAS
    Dont
    I went through 3 of them and they started to fray open on the edges. Weird because Wagner is a Great company
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    oiled (cotton or foam) filters might be outdated, I moved from pipercross to sprintfilter and maintenance wise is much better because it doesn't need to be reoiled at each cleaning. About performance, they claim polyester has a better filtering capacity combined with better air penetration, but have no idea nor I made a comparison test
    https://www.sprintfilter.net/automotive/whysf
    2020 TT- RS
    ex 2018 TTS
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Quote Originally Posted by kevin#34 View Post
    Not very scientific, I know. But after seeing this video, I'm staying with the OE filter. If I must, I will rather go with a dry cotton filter than those sprint filters.
    https://www.youtube.com/watch?v=nZ0YEPR1pJ8
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I have/had a K&N drop in filter and it positively yielded a solid 1mph on my previous personal best. I want to emphazise that I did not round out the number, I didn't increased .9 mph or 1.4 mph on my traps, it was exactly a solid 1 MPH. My previous record was 126.94 mph and after the K&N I ran 127.94 mph on just stage 1 E-85 (Unitronic)and by the way, look on the registry and see where I sit on that trap speed and that was done at 3100ft of elevation.
    Now I am using the same K&N drop in filter that was on my 8V RS3 and I put it on the 8Y RS3. Look at my trap speed for a stock car(with the drop in), I trapped almost 121mph with no tune and that was again at 3100ft elevation. Do I recommend the K&N ? hell yeah.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Nov 11 2021
    Atlanta, GA
    Quote Originally Posted by S3DUDE View Post
    I noticed a nice difference on my TTRS as well with the K&N drop in.
    Nov 09 2022
    Charlotte
    Quote Originally Posted by XMetal View Post
    That's not a relevant experiment because street cars will never experience such particulate loading. Paper elements provide superior filtration, I don't think anyone argues that, but I've never heard of accelerated engine wear running performance air filters unless you're driving through a sand storm. if you look in the intake tract you won't see anything (if it's properly installed and oiled if required)
    I prefer Green filter to K&N but don't think they make one for the RS3
    2023 Tango Red RS3
    Mar 09 2018
    2018 RS3
    I have a spare K&N filter around somewhere. I think BMC makes a panel filter. From what I hear BMC is better than K&N.
    I've come across an ebay non-oiled filter. https://www.ebay.com/itm/18445233967...mis&media=COPY
    Florett RS3+DS1+034TCU
    Jul 13 2018
    Quote Originally Posted by fzr100098 View Post
    Here's a better test https://www.youtube.com/watch?v=YypvDEQyNBY
    These drop in filters really do allow more dust into your engine for trivial amounts of power. The K&N filter performance was comparable to no filter at all and looked nearly transparent when held up to the light.
    Nov 09 2022
    Charlotte
    How does "dust" equate to engine wear is the question (on the street) - probably goes right out through the exhaust valves. Good oil filter is more important imo, in addition to 5k oil changes (10k is insane and more a marketing ploy)
    Yep, I prefer Green filter to K&N - it's probably worth 5-7 hp
    2023 Tango Red RS3
    Nov 02 2017
    CA
    If this is what you believe and how you rationalize it, then why not run no filter? Why even bother putting in a filter if "dust" will probably goes right out through the exhaust valves anyway?
    May 10 2018
    MA
    Quote Originally Posted by TheContrarian View Post
    A paper filter is similarly see through under a bright light. It would have to be.
    They filter down to around 25 microns. The key to it working well, is keeping it clean: just like the key to a healthy engine is frequent air filter changes (more than the manufacturer suggests) and oil changes. Dust in the engine happens. It can’t be avoided. Oils job is to hold such things in suspension. The upside to the filter isn’t really “power” to me. It’s reuse-ability. Measuring any intake on a dyno is tits on a bull.
    May 10 2018
    MA
    Fwiw, 10k isn’t a marketing ploy at all. Ask actual triboligists. Oil can go that long, and more. If certain conditions are met. If the conditions aren’t met consistently, shorter intervals are needed.
    Nov 09 2022
    Charlotte
    Quote Originally Posted by RMode View Post
    A light duty Accord might be ok running 10k intervals, not a high power density forced induction engine driven aggressively - they all have fuel contamination. Yes, it's marketing - they want to sell people on low maintenance, and they don't care much about longer term (> 100k miles) longevity - why would they?
    How many of these boosted to the moon engines are going to hold compression at 250k miles like a V6 or 4 cylinder n/a Accord? None
    I don't trust Blackstone, either - use OilAnalyzers https://www.oaitesting.com/
    I think that's obvious - you don't want larger particulate in the motor
    2023 Tango Red RS3
    May 10 2018
    MA
    Accords aren’t NA. Virtually nothing is nowadays. They haven’t been NA in 6 years I believe.
    Did I say a thing about Blackstone?
    Again, intervals are wholly dependent on use case.
    . Some of my cars I go long, some I don’t. It’s served me well since forever, and I’ve had virtually nothing but performance oriented machines
    Jul 26 2018
    TEXAS
    for me, as a general rule on any performance car I do OCs at 4k. Regardless if its OTS synthetic or boutique oil. Even the most robust additive packages breakdown fairly quick with heat cycles seeing 220+ oil temps. on my NA civic however, I was doing OCs at 9k and after analysis I still go 2-3 more
    May 10 2018
    MA
    Quote Originally Posted by ZTTRS View Post
    They really don’t, that’s precisely the temps (220-250) modern oils work their best at in fact. But it’s all conditional based on fuel, environment, avg trip distance and sustained temp (sustained temps are good, short bursts aren’t) stock motor, built motor, and more.
    Don’t get me wrong, frequency is cheap insurance, especially on a DI engine, that sees short trips so rarely at or sustained temps especially modified on the fuel side of things But the 10am interval isn’t a myth as suggested above.
    Aug 29 2017
    Tucson, AZ
    Not to say that you are doing anything wrong by changing the oil at 4k, I wouldn't argue that changing the oil that often benefits the engine but I would also say that if you are not beating on the car and you drive "relaxed" and highway miles and not building a lot of heat by reving high you are probably fine with longer oil change intervals. 7500 miles is also very aceptable. I know now days most dealers offer a 10k oil intervals but everything is very subjective and like you said, a lot of car manufacturers want to pull the marketing card: "free oil changes for the first 2 years". As it turns out that often means maybe one oil change because people wouldn't even drive 10k miles a year.
    So in summary, yes, you are doing good and you are being proactive. You are changing the oil in a shorter intervals because you value your car very much and there is nothing wrong with that.
    at 3100ft elevation
    Jul 26 2018
    TEXAS
    its a mix of both, hard driving and cruising. After performing numerous Oil analysis here at my job from all my past cars, I started seeing the additive packages and detergents begin breakdown around 3k and thermal degradation starting at 220-230 depending on oil and additive package. These were all in cars above 550-600whp< I just went with 4.5k. Now my little 1.8 Honda Civic I stretched out very comfortably to 9k. You are for sure right though, I am overly proactive lol
    Mar 09 2018
    2018 RS3
    I rather change my oil more frequently with cheaper oil than to stretch my oil changes with pricier oils. Following manufacturers recommendation is to save the earth and resources.
    It's not even about the additive packages in the oil... A good amount of soot particles do get into the oil on DI engines that's why I prefer 3-5k oil changes.
    Nov 09 2022
    Charlotte
    For turbo DI cars 10k is insane - I've probably seen more UOAs than you have in 30 years. Again, they all have fuel dilution to one extent or another
    Well aware the Accord went turbo starting in 2018 haha, I've only owned about 5 of them, that's why I said "n/a Accord". I will say the 2.0L in the Accord and Type R has an ingenious system to reduce blowby and fuel contamination
    2023 Tango Red RS3
    Nov 09 2022
    Charlotte
    Quote Originally Posted by tegxsi View Post
    BMC seems to be the only alternative at this point
    Edit - UroTuning sells one manufactured by Masata, never heard of them
    2023 Tango Red RS3
    Jul 26 2018
    TEXAS
    RAMAIR pro ram makes a dryflow drop in--- https://www.all-stars-motorsport.com...185619198.html
    I have one for sale, barely used
    Nov 09 2022
    Charlotte
    Went back to stock filter?
    2023 Tango Red RS3
    Jul 26 2018
    TEXAS
    bought a Blaze intake
    Aug 29 2017
    Tucson, AZ
    How do you like it?
    at 3100ft elevation
