Friends Q7 TDI. Cooling fan died and it overheat. He got it to me in limp mode from being overheated, and figured out upper hose cold and no coolant flow. Replaced thermostat and water pump and cooling fan. (Found stuck melted tstat)
All seems well and got coolant to flow again in expansion tank(stone cold before), but there's no heat in front or rear unit and still overheats.
Stopped up heater core? This thing has 2 one in front, one in back. So both heater cires stopped up??? Seems odd also can't seem to find heater hoses in engine bay on this TDI?
Blows ice cold AC, no heat whatsoever.
Note: lots of corrosion in old coolant and wrong coolant was used. The rad hoses were "crunchy" feeling when squeezed when I first got it before draining old coolant etc.
