Results 1 to 5 of 5
    Aug 09 2023
    Ottawa
    2015 RS5 common problems to look for?
    I am in the market for a 2015 rs5 and I couldn't find a thread on here about common problems to look for.
    Is there anyone here with knowledge of the 8.5 rs5s that wouldn't mind sharing some advice on what to inspect and look at?
    The particular vehicle I am looking at has about 60k miles and just had all of its brakes changed and major maintenance done.
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    They are honestly very stout cars. Especially well maintained ones. Outside of an occasional dsg mechatronic issue I haven’t seen many problems in any of the years.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    Nothing much other than Mechatronics issues.
    Things ask about or look for:
    Carbon clean done (depends milage)
    Brakes wear. Only because they are expensive and if they are due for replacement you'll need to budget some $
    Always best if the current owner has the service history.
    Sent from my Pixel 7 Pro using Tapatalk
    Junior Member Two Rings
    Oct 26 2020
    St Louis MO
    Echo the others here. Had my 2015 for 3 years now, no major issues. Brakes coming up (45k) and not looking forward to it! As long as the maintenance history is there, especially with the differential, should all be good. I'm pretty sure the major mechatronics DSG issues were sorted by 2014, so thar should all be ok.
    Sent from my SM-G991U using Audizine Forum mobile app
    2015 RS 5 Cabriolet
    2014 Q5
    2012 S4 (sold)
    2010 A5 3.2L (sold)
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    The engine is a high revving machine with tight tolerances. Use a top quality oil and don't wait for Audi's ridiculous 10k change interval or you are prematurely wearing out your engine. Can't believe they have the same Mx interval as a A4/A5 2.0t.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
