Results 1 to 35 of 35
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Mag-Ride delete options
    I am looking to make some suspension mods as part of general maintenance and will be moving away from the OEM Mag-Ride and moving to Bilsten B8s with H&R springs (amounts other goodies )
    What are the options to 'delete' the Mag-Ride system to keep the lights off the dash and error messages/codes being thrown?
    From what I can research there is not a documented way to code them out with VagCom or ODIS, and the iSweep cancelers work most of the time, for most people.
    Is there a rock solid solution?
    2019 SQ5 Prestige
    Veteran Member Three Rings Eli0073's Avatar
    Jul 17 2020
    USA And Finland
    uxcell 2pcs Aluminum Case Resistor 100W 10 Ohm Wirewound Yellow for LED Replacement Converter 100W 10RJ https://a.co/d/1DvGRkf
    $8.99 in Amazon. Remove the plug from your mag rides and the plug to get access to the 2 wires. Use those 2 wires positive and negative and solder them to each side of the resistor. Heat shrink, electric tape. And done.
    Sent from my IN2017 using Audizine Forum mobile app
    May 15 2022
    Massachusetts
    I just installed Bilstein B8s after going with just APR springs on Mag Ride for a year. Car has 76k and it's a night and day difference. Even my wife noticed the difference as a passenger. I got the EQT mag ride delete and its ok. It was the cheapest kit at $225. You're not supposed to use Dynamic mode with cancellers, apparently. Before realizing that I did throw an error that went away once I started the car again. They suggest you use individual with all of the Dynamic settings, except suspension, to achieve the use of the steering and exhaust difference. I think EQT is out right now, however, as they are supposed to be coming out with an improved version.
    Apr 01 2007
    houston texas
    Quote Originally Posted by Eli0073 View Post
    That simple..??
    Can you point me to other folks/documentation support its as easy as soldering in a resistor?
    2019 SQ5 Prestige
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Stage 1 more than you RS3
    Jul 17 2020
    USA And Finland
    Quote Originally Posted by texasboy21 View Post
    That simple..??
    Yes is that simple. Those kits are the same thing. Try it out. Is cheap enough.IMG_20230810_083113.jpg
    Jul 17 2020
    USA And Finland
    I can't point you to documentation. It was shared with me by a friend who did it. With zero issues. He's a knowledgeable guy with plenty of experience in the MQB platform I trust his knowledge.
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    May 01 2021
    Michigan
    TAG is a great seller.
    May 15 2022
    Massachusetts
    No longer working with EQT?
    Dec 25 2004
    Earth
    Quote Originally Posted by murph3699 View Post
    I dont know...I bought a set of his early versions...then he moved to EQT last I heard...few months ago...
    May 15 2022
    Massachusetts
    Quote Originally Posted by MikTip View Post
    I think he might be back on his own. He's selling updated kits for the 8V. I spoke to him today and he's a solid guy and 100% backs his product. I was having issues with the EQT version and let's just say I'm happy with his response.
    Dec 25 2004
    Earth
    Yes. He supported the early version I had.
    Apr 01 2007
    houston texas
    Hearing that someone has "supported the early version" and "backs his product" sounds like more of hits hit or miss..
    2019 SQ5 Prestige
    Dec 25 2004
    Earth
    Not really...Mark...months ago...was trying to develop mag ride cancelers for a much lower price than $400...all on his own from his home.
    He needed people to install and test. He offered full refunds if you were not happy with the product. He also offered newer revised product as it developed.
    Move forward several months and he now offers mag ride cancelers for $250 & $150 vise $450.(isweep)
    So he accomplished what he set out to do in the beginning.
    In my opinion...all his efforts benefit us...the consumers. First by developing his product and still offering it at a lower price.
    I have nothing but praise for him.
    May 15 2022
    Massachusetts
    100000%
    Apr 16 2021
    Washington NJ
    Question for you re the Bilstein/H&R combo. Have you experienced that combination on current or other vehicle?
    Sounds like a good match, I remember hearing positive feedback (and think I had that combo on an old GTI)
    I currently have 034 Dynamic springs with Mag-Ride on 2018 S3 and not completely happy; feels like car has lost some of its composure on twisties
    I've heard that springs and shock/struts should be well-matched (but no idea what that means)
    An issue that could be avoided with coilovers (V3s, eg), though may be overkill as I'm not planning on tracking the car...
    Dec 25 2004
    Earth
    Quote Originally Posted by Pete Moss View Post
    I have H&R Sport(not super sport which IMO are too low)springs and Bilsteins on my 2015 and APR springs and OE Mage ride on my 2018. I had 034 once...didnt like'm...
    Do you switch the drive to dynamic when hitting the twisties?
    The well matched is the coil-over kits. As the springs are matched to the shocks.
    Or get a set of fully adjustable shocks with or without springs...as it seems everyone has different tastes of their suspension setups...
    Jul 20 2019
    What sort of issue with the EQT version? I have a set waiting to install here in the next few weeks.
    Apr 16 2021
    Washington NJ
    How did you like the Bilsteins with H&R?
    Better than stock?
    Drive in Dynamic Mose about 95% of time. Feels like the car went from understeer to oversteer at steeper sweeps with the 034s.
    May 15 2022
    Massachusetts
    Quote Originally Posted by aaronc7 View Post
    Just random intermittent errors. Its also not recommended to use them in dynamic mode.
    Jul 20 2019
    Alright, thanks. I assume because comfort suspension mode pushes the least amount of power thru the resistors/least amount of heat? We'll see how my install goes I guess. Did he offer any tips for the errors?
    May 15 2022
    Massachusetts
    He's replacing mine
    Nov 13 2009
    the OC, SOCAL
    so which one is the newest one from tag?
    I'm always into supporting the small business that makes products that works better and with the bonus of being cheaper.
    cheaper is usually very hard to do with a small biz.
    Dec 25 2004
    Earth
    Quote Originally Posted by 949 View Post
    The ones I have pictured above...
    However, you might want to confirm from the source which are
    Jul 20 2019
    He's replacing mine
    Looks like I am getting "current implausible" error for 2 of them. I'll drive on em a bit more to gather some more data and then hit him up.
    May 15 2022
    Massachusetts
    I haven't had a chance to put the new ones on yet, hopefully this week, but in the interim I'm getting errors maybe twice a week. They clear if I stop and start the car but do get stored when I scan with OBD11.
    Jul 20 2019
    In addition to just driving a bit more I'm going to try a level sensor recalibration, which seems to be part of the equation for all of this. If that doesn't work, I'll be going the same route and try the new mag ride delete modules. I did email Mark and he got back to me late Saturday night-- very responsive and helpful.
    Junior Member One Ring
    Jul 20 2023
    Montreal
    Are you sure the b8 struts can handle the spring rate of s3 springs/ aftermarket s3 springs?
    The b8 is the same part number used in the gti/R but those have much softer springs both oem and even aftermarket.
    R springs 195 in/lbs 245 in/lbs front rear vs 320 front 400 rear for s3.
    Jul 20 2019
    I'm not really sure. But bilstein offers it as a solution for the 8V S3. They don't market it as compatible with the VWs which is kind of weird, but that seems to be the case.
    Dec 16 2020
    Polska
    Hello, I have these resistors 100 W 1 ohm installed and unfortunately after starting an error pops up every time. Does the soldering of the cables matter in which direction, or maybe the resistors have to be stronger, best regards.
    Dec 25 2004
    Earth
    Quote Originally Posted by Kokos View Post
    Ya might want to reread the #2 post above as theres some differances with what you have and what was posted above...
    Apr 01 2007
    houston texas
    FWIW I went with the iSweep cancelers and have NEVER had a soft or hard code thrown!
    For an apples to apples comparison, a fellow autox buddy has the KW cancelers on this 2015 with Bilstein B8s and H&R springs, and EVERY event he gets both soft and hard codes thrown that neuter the car's performance. No issues with driving on the street.
    This 'side by side' example plus all the comments here about TAG issues, revisions, etc. really solidify that the iSweep are superior and truly a 'set it and forget it' install IMO.
    2019 SQ5 Prestige
    Dec 16 2020
    Polska
    Ok, so I should have stronger resistors, in post 2 these resistors are supposed to be 100 W and 10 ohms but in post 6 the photo shows a 100 W and 1.5 ohm resistor.
    Dec 25 2004
    Earth
    I have isweeps...
