Originally Posted by
PassionForAudi
Can’t go against you there. 1-10 on difficulty degree to install those things, where would you scale it? Appreciate the help.
I'm not going to lie; scale of 1-10 I'd give it a two and I'm no mechanic.
It's so easy. If you purchase IE's links the instructions will tell you to remove the wheels but you do not need to. Just get the car up on the lift or jack/jack platforms, pop off the OEM's, adjust the links to the height you think you want, pop them on, take the car down, turn it on letting the MMI recalibrate for a few seconds, check the height and then repeat if you want to adjust lower.
Here's a vid from YouTube that does a pretty good job showing the process.
As well, here's maybe a better pic of mine than the original in the post. This one with the car turned on and in the sun. As you know, when the car is off it sits a little higher and then readjusts once the ignition is switched back on, so it's sitting at the lowest ride height per my links in this image.
[IMG]
[/IMG]
