Hi All,
I recently decided to tackle the fun job of replacing my 2006 Audi A4 balance shaft. I've been getting low pressure readings and figured that was the culprit. I purchased a rebuilt balance shaft on ebay. After disassembly I confirmed that my old balance shaft was definitely the culprit. The question I have is this; the new balance shaft sprocket does not have the timing mark on it as the old one does. That being said, does anyone know what position should the weights be in when the sprocket is in the TDC position? Since I don't have the timing mark on the sprocket, I'm hoping I can figure out the TDC point by the position of the two weights. I don't want to use my old balance shaft as a guide since I believe it was most likely shot and may have gotten out of timing. I've heard some people say that the weights should be in their natural BDC position (meaning the flat part of the weight facing you as you look down at the balance shaft assembly). I just need to get some confirmation before I start re-assembly. Thanks in advance.
