Results 1 to 26 of 26
    Aug 03 2023
    Sf
    Vag eeprom software
    Hello all, I’m new here, but I am having issues with my b6 a4 and need to retrieve my immobilizer skc. After doing some research I found that vag eeprom 1.9 is the best option, the only issue is that when searching for where to get it from i only find sketchy download sites. Can someone who has the program please point me in the right direction?
    Thanks in advance.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    I might have a copy of it. Will look for it later.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Aug 03 2023
    Sf
    Thanks, would really appreciate it.
    Jan 24 2010
    Paramus,NJ USA
    Not to be a dick but it would be great if new users just used the search function. It's been discussed and posted on there numerous times.
    Search here
    Ziddy Autowerks
    Junior Member Two Rings chuckn0rr1s's Avatar
    Jan 12 2019
    BMW 335d, B6 Avant
    Pineland, NC
    Quote Originally Posted by EuroxS4 View Post
    Search here
    That link to me to a website that asked me to type in "vag eeprogrammer v1.19g" lmgtfy.com to be exact. It seemed very sketchy... Is that the correct link or did someone hack it?
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    I was like "hmm I think I have a copy somewhere" *looks up at other monitor and its directly in the center of my desktop*
    Here you go. Link expires in 3 days
    https://litter.catbox.moe/aa0t93.zip
    I encrypted it with a password, also as a passive aggressive way of shaming you for not finding it yourself.
    I was going to throw in a goatse.jpg into the folder but decided against it.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 12 2013
    Houston, Texas
    Thanks Gunnarrrrr. I too have a few copies downloaded from some very sketchy places. I didn't have the guts to mess with my SKC with any one of those versions. I have no clue what could have been sideloaded into those copies. I'm keeping yours as the go-to from now on.
    Mar 25 2015
    Placer County
    I’ve had a few copies from questionable sources that may or may not have worked, but i’ve done a few cluster swaps with this copy now without issue
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Dec 08 2018
    South Yorkshire, UK
    Quote Originally Posted by Gunnarrrrr View Post
    Hi Gunnarrrr,
    What cable are you using with this. I have VCDS cable. will that work or do I need a clone type cable.
    Thanks
    Larry
    Larry
    2002 A4 B6 1.8T
    Tuned Stage 1, BSR exaust, RS4 rear sway bar, A4 B7 320mm Brembo disks, calipers, SS brake Lines, B7 wiper arms and blades, Valeo HD SMFW Clutch.
    Mar 25 2015
    Placer County
    you need a ch340 or ftdi cable.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jan 12 2020
    NA
    You know how hard it is to find an OG copy of goatse if you didn't already have one saved? It's like the internet has purged it from normie web.
    Jan 15 2024
    bc canada
    Hey guys I'm new to Audizine and can't figure out how to start a new thread. Sorry not trying to high jack. I downloaded vag eeprom 1.19 off some scratchy website and for the life of me can't get it to work. I'm using a kkl 409.1 amazon cable with a ftdi vcp driver installed. Any chance I could get a copy of a vag eeprom from one of you that I know works!
    Feb 14 2016
    2007 VW Touareg
    Calgary
    HI, Gunnarrrrr
    Any chance I could grab a copy of VAGCOM eeprom as well?
    Thanks,
    Tamas
    Mar 25 2015
    Placer County
    Quote Originally Posted by t.farkas View Post
    HI, Gunnarrrrr
    Thanks,
    Tamas
    Quote Originally Posted by legs View Post
    no guarantees on how long this link will be up. Password for the zip is my username, capitalized, copy/paste it.
    https://files.catbox.moe/cv76cg.zip
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Feb 21 2017
    Denver
    I've read you need windows 7 to get it to work. Any newer version of windows OS isn't compatible.
    Mar 25 2015
    Placer County
    this may sound strange, but for laptops i’ve always needed windows 7 to get it to work. However, I’ve used bench harnesses with clusters on two different desktops on windows 10 and 11 and it worked flawlessly every time. Just never worked on anything other than windows 7 on any laptop i’ve ever tried.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    May 13 2024
    Central Oregon
    Well I've searched high and low..unable to find a active download link. Can anyone help me out with a download for VAG EEPROM 1.19? Thank you in advance!
    Greubin
    2004 Allroad
    Mar 25 2015
    Placer County
    Quote Originally Posted by VwNutz View Post
    Greubin
    2004 Allroad
    https://files.catbox.moe/tv98y7.zip
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    May 13 2024
    Central Oregon
    Thank you
    Aug 23 2015
    Las vegas
    if you stumbled upon this thread looking for vag eeprom the last two links work as of 01/13/2025. Gunnarrrrr is a real one! thanks a lot!
    May 09 2012
    Virginia
    Subbed so I can download when I get to my computer. Thank You!
    Sep 16 2010
    Central Wash
    I've hosted on my G:drive for years.
    Good luck getting it past windows defender.. it's a VIRUS!! Seriously, sometimes you have to get forceful with the download.
    VAg EEPROMMER
    Jul 07 2024
    Elk Valley, BC, Canada
    Same experience here, I was running it fine in a windows 10/11 virtual machine on a Linux box, but it (and "my copy" of vcds lite) refused to work on my laptops with anything other than windows . I do now have a windows xp virtual machine that I spin up on a MacBook for VCDS and VAG EEPROM now though instead of the dedicated laptop.
    Edited to remove iPhone app emoji barf...
    Jul 07 2024
    As a side note, if you do have a spare cheapo laptop you can dedicate to sketchy software it's a good idea to just never connect it to a network (even when installing the os, only ever use a usb key to move data to it from another computer). Or use something like virtual box without any of the sharing features enabled...
    Sep 16 2010
    Central Wash
    Quote Originally Posted by willemml View Post
    THIS ^ is exactly what I have and do. Bought OLD giant Win7 laptop that does nothing but OBD.
    Mar 25 2015
    Placer County
    I’ve since retrofitted three different clusters with windows ten. sometimes it just works
    I didn’t quote reply because of the emoji problem, if you avoid all numbers it doesn’t do it.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
