Results 1 to 22 of 22
    Junior Member Two Rings
    Jul 25 2023
    Catted downpipes
    Researching next round of mods and I’m unclear on which direction to go with downpipes.
    All 3 feature on the drag times for multiple vehicles….
    034 @ $1,700
    IE @ $1,000
    CTS @ $600
    This cost spread is significant and based on price, CTS is the best dollar value. Does anyone have feedback on the differences?
    Jan 11 2020
    Ontario
    Quote Originally Posted by nwapache View Post
    034 @ $1,700
    IE @ $1,000
    CTS @ $600
    I'd get the least expensive one if you make, or plan on making, anything significant over stock power. Eventually, they all "shred". My AWE performance cat lasted about 1.2 years before shredding.. and this was when I was only making around 430-ish WHP. Others I've known had the same issue... seems like running ethanol really shortens their life.
    2018 Audi S4 Prestige - Daytona Grey
    Logic Street Performance custom tune via Deadbeef Flash platform | Andy's Big Ass CF Intake | 034 J Hook Rotors | iSweep 2000 pads | Valved Exhaust Titanium straight pipe | CAP Decat 2.0 revision | CTS Turbo Intercooler | APR DTR8868 Turbo + RS Injectors + HiFlow HPFP + LPFP | Osman BicepBrah Ali PCV fix | OEM 4-bar MAP sensors
    Senior Member Four Rings
    Nov 20 2021
    United Kingdom
    I'd have to agree with the above comment tbh. There's been failures from every manufacturer.
    Saying that, IE will likely be the easiest to install.
    Build Thread: Audi S4 B9 with G35-1050 and Built Engine
    - Custom big turbo G35-1050 (0.83 AR)
    - Fully built shortblock and ported heads
    - Added port injection and direct meth injection
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    If you are going to do a downpipe at all I seriously wouldn't bother unless you went to catless. The best aftermarket downpipes are really only a marginal difference from OEM. Alot like an intake, the biggest effect is noise.
    Jul 25 2023
    Quote Originally Posted by Jetta03 View Post
    Interestingly, 034 requires a DP for stage 2 tune. Id happily go catless… but ive heard the smell is quite noticeable. Thoughts on smell?
    Administrator Three Rings oesman's Avatar
    Oct 08 2016
    Houston
    If you run E85 the smell isn't as bad, it burns much cleaner than straight pump gasoline.
    Jan 11 2020
    Ontario
    You'll have that exhaust smell but, it can really be minimized if you have fresh seals installed when swapping. Otherwise, it's not pleasant.
    Jul 25 2023
    Quote Originally Posted by oesman View Post
    Washington has 7 E85 gas pumps, only 1 of those is within 100 miles of my house. Similar issue with 93 Octane. I think ill try Klotz and run the 93 tune.
    Meanwhile, i can A- leave the dp alone and suffer quietly. B- get a catted dp and await failure while being out of pocket $600-$1600 or C- enjoy the lovely aroma unburnt fuel in my cabin while road tripping with my wife.
    Hmmm
    Jan 11 2020
    Ontario
    Hmmm
    When/if your cat fails, you can always gut it :-)
    Nov 20 2021
    United Kingdom
    I’ve been running catless in my S4 for years. Only smells if you’re sitting in stationary traffic for prolonged periods of time with the windows down.
    Jul 25 2023
    Quote Originally Posted by AldermanToffee View Post
    That totally reframes the conversation, thanks for clarifying
    Jan 29 2020
    Correction, it only smells FOR YOU if you're sitting in stationary traffic :)
    Kind of like crop dusting as you leave an elevator... for everyone else it smells the whole time.
    Jul 25 2023
    Kind of like crop dusting as you leave an elevator... for everyone else it smells the whole the time.
    So, the smell is coming out of the tail pipes and flavoring the intersection, water box, driveway, whatever
    Oct 08 2016
    Houston
    I think it will depend on how sensitive you are to the smell. I can tell you that catless on pump gasoline is not a smell most people like, and it can get pulled into your car even with AC on if you aren't recirculating. Also it will smell for everyone else, you've probably smelled that before. It will also smell in your garage if you start it without ventilation to take it outside. The water box probably isn't a worry since lots of cars will likely be catless. If you run race gas catless it smells great, like old school magic markers. If you run E85 catless to me it's like a very watered down gasoline smell, others say they like the smell.
    It's amazing how well the catalyst works, these cars really don't smell at all stock. Even a race cat will do a better job, except maybe at cold start while the O2 sensors are heating up, u might get a tiny whiff. There's also a consideration if the car is your daily and you really wanna drive catless from an environmental perspective. I'm not a huge environmentalist or anything and am not trying to shame anyone, but just personally if I drove several thousand miles a year without a cat I'd feel a bit guilty about it. I have a catless car, but it's mostly a track/toy car that sees very few miles a year.
    Jul 25 2023
    I thought you had an 034 catted DP? Did i miss a video or is this a new development? This car is a weekend toy for me.
    Oct 08 2016
    Houston
    Yea I do, my catless car is a different car ;-). The 034 cat is a race cat so it's not going to be quite as efficient as the stock cat. I really like the build quality on it.
    Nov 20 2021
    United Kingdom
    Hah, I figured that was self explanatory.
    Established Member Two Rings Pocket Cub's Avatar
    Aug 19 2018
    Westchester, NY
    I got a CTS high flow catted downpipe. Im also IE Stage 2 93. And it’s been super good so far.
    2018 S4 - IE Stage 2, CTS High Flow Downpipe, CTS Transmission insert, AWE Airgate Intake, CTS Turbo Inlet-
    Current: 2018 B9 S4, Black Optics, S Sports Package, Sports Differential, Napa Leather, Tech. Package
    Sold: 2013 MINI Cooper S
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Well, also when you're in the garage, starting the vehicle and backing out through the pume of exhaust, vehicle running while stationary or stop and go traffic, or stoplight, and the sunroof is cracked, and the wind is blowing in any other direction other than front to back, every time you fill up, and walk around, you get to enjoy the remnants, etc.
    As raw and unpleasant as it smells, I kinda enjoy it, so I don't mind it, but a day does not go by when I don't smell it in my car. Seals are fine.
    '18 S4 Prestige; all packages
    Nov 20 2021
    United Kingdom
    Quote Originally Posted by SHCKR View Post
    I can understand smelling it when backing out of a garage. I personally don’t have any issues with smelling it unless I’m sitting in traffic for ages though. Maybe I’ve just been lucky.
    I’ve gone through a few exhaust setups in that time too.
    I am putting a screamer pipe down under the passenger though so I imagine I’ll probably smell that..
    Jul 25 2023
    Quote Originally Posted by Pocket Cub View Post
    How long have you been running it? And are you concerned about it delaminating?
    Apr 07 2011
    Home of the mighty beaver
    this. Its gross for everyone.
