A buddy of mine bought it last October and when I scanned it in Oct 2022 it had 2 fault codes.
2 Fault Found:
14221 - Cam Adjustment Actuator A; Cylinder 5
P11B1 00 [039] - Elec. Malf. or Open Circuit
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 176243 km
Date: 2023.07.29
Time: 20:01:39
Engine speed: 667.00 /min
Normed load value: 6.3 %
Vehicle speed: 0 km/h
Coolant temperature: 80 °C
Intake air temperature: 34 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 13.805 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 1110 1101
18742 - Control Module for Exhaust Flap
P14AB 00 [100] - Mechanical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 159204 km
Date: 2022.10.18
Time: 15:00:45
Engine speed: 2088.50 /min
Normed load value: 7.1 %
Vehicle speed: 26 km/h
Coolant temperature: 97 °C
Intake air temperature: 38 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 14.206 V
Readiness: 0000 0000
On Saturday July 29th, the car would not turn over, the EPC light came on. We tried several times but it wouldn't turn over, we thought it was the battery but were not sure.
After leaving the car alone for 10 mins and starting it again, it started but the engine was knocking, we drove it like that back to his place and I pulled the codes and there were several inclduing a new one for knock sensor.
I would apprecaite any feedback from the community. Also if anyone is aware of any great private shops around the Pittsburgh area that would be awesome, would like to avoid taking it to the stealership.
Saturday,29,July,2023,20:03:45:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WAU32AFD3FN006102 License Plate: MOEEN BHAI
Mileage: 110K Repair Order:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4H0 906 014 J HW: 4H0 906 014
Component and/or Version: 4.0l V8TFSI / H62 0006
Software Coding: 022A00326546010E3000
Work Shop Code: WSC 07674 006 1048576
ASAM Dataset: EV_ECM40TFS0114H0906014J 001006 (AU64)
ROD: EV_ECM40TFS0114H0906014J.rod
VCID: 2A5BB7AF4DFF20D66D-807E
10 Faults Found:
P11B1 00 [175] - Elec. Malf. or Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 166558 km
Date: 2023.04.28
Time: 17:55:50
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 94 °C
Intake air temperature: 51 °C
Voltage terminal 30: 11.732 V
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
P14AB 00 [108] - Mechanical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Mileage: 169596 km
Date: 2023.05.17
Time: 15:59:06
Engine speed: 1521.50 /min
Normed load value: 5.1 %
Vehicle speed: 92 km/h
Coolant temperature: 101 °C
Intake air temperature: 39 °C
Voltage terminal 30: 13.829 V
Unlearning counter according OBD: 36
18740 - Control Module for Exhaust Flap 2
P14AC 00 [108] - Mechanical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 174616 km
Date: 2023.06.14
Time: 21:41:02
Engine speed: 1922.00 /min
Vehicle speed: 116 km/h
Coolant temperature: 98 °C
Voltage terminal 30: 13.758 V
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 78 °C
Intake air temperature: 69 °C
Voltage terminal 30: 11.332 V
2925 - Knock Sensor 2 (G66)
P0333 00 [104] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Mileage: 168489 km
Date: 2023.05.10
Time: 15:07:30
Engine speed: 1969.50 /min
Normed load value: 21.6 %
Vehicle speed: 119 km/h
Coolant temperature: 100 °C
Intake air temperature: 45 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.240 V
Unlearning counter according OBD: 37
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [036] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 176217 km
Date: 2023.07.28
Time: 23:22:51
Engine speed: 1244.00 /min
Normed load value: 7.5 %
Coolant temperature: 75 °C
Voltage terminal 30: 13.476 V
Unlearning counter according OBD: 80
10591 - Cylinder 1
P0301 00 [036] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 176234 km
Date: 2023.07.28
Time: 23:42:00
Engine speed: 1456.50 /min
Normed load value: 27.5 %
Vehicle speed: 89 km/h
Coolant temperature: 103 °C
Voltage terminal 30: 13.640 V
Fuel pump: specified value: 32.457 %
Fuel low pressure: actual value: 519.2 kPa
Low fuel pressure: specified value: 520.8 kPa
O2 sensor 1 bank 1: O2 sensor actual value: 0.9978
O2 sensor 1 bank 2: O2 sensor actual value: 1.2808
Selector lever position-Bits 0-7: 5
10595 - Cylinder 5
P0305 00 [036] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 176217 km
Date: 2023.07.28
Time: 23:22:52
Fuel pump: specified value: 32.574 %
Fuel low pressure: actual value: 587.0 kPa
Low fuel pressure: specified value: 600.0 kPa
O2 sensor 1 bank 1: O2 sensor actual value: 1.0076
O2 sensor 1 bank 2: O2 sensor actual value: 1.0105
Selector lever position-Bits 0-7: 8
10205 - Cylinder Disabling
P130A 00 [036] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 176217 km
Date: 2023.07.28
Time: 23:23:03
Engine speed: 1560.00 /min
Normed load value: 5.9 %
Intake air temperature: 67 °C
Voltage terminal 30: 13.546 V
7781 - Engine Off Timer Performance
P150A 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 176147 km
Date: 2023.07.23
Time: 15:15:11
Coolant temperature: 74 °C
Intake air temperature: 59 °C
Readiness: 0010 0001
