Results 1 to 36 of 36
    Veteran Member Three Rings Auditography's Avatar
    Aug 19 2005
    RS4 B5/B7/B8, RS6 C7.5, Q5 Caractere, A4 B5
    Doha
    Finally! The 653hp Audi RS3R MTM 8Y - Detailed video + Wallpapers
    Hi there.
    It took a good while, but finally the new RS3R MTM is out. 653hp is quite insane, and I had the privilege to be the first one to test it, and I took it to the Austrian Alps. Enjoy the video and the wallpapers. Thanks!
    Detailed video:
    Wallpapers:
    My Garage:
    2017 Audi RS6 C7.5 Avant Meissen blue, ABT, Stage 2+ 750hp, custom interior
    2001 Audi RS4 B5 Avant Nogaro blue edition, Stage 3
    2008 Audi RS4 B7 Saloon Sprint blue
    2015 Audi RS4 B8.5 Avant Mystic blue pearl, orange seats
    2011 Audi Q5 3.2 Quattro S-Tronic Widebody, Riviera blue
    2001 Audi A4 B5 Turbo 300hp only owner, Santorinblue
    IG: auditography
    Junior Member Two Rings Asharp's Avatar
    Nov 25 2019
    2019 RS3 Glacier White | 2021 SQ5 Mythos Black
    Lakeland, FL
    Always appreciate your videography.
    Seats are amazing
    2019 RS3 - Glacier White
    Sep 12 2022
    South Jersey
    What did they do to get 653hp from that?
    Aug 31 2021
    Oakland CA
    Details are overwhelming
    Junior Member One Ring
    Jul 18 2023
    GT3, X7
    Central CA
    Car looks amazing. So I'm assuming MTM was able to crack the ECU? Limited details, but I believe they noted a "retuned ECU/TCU" in the video? The other modifications seems to be standard to what others have done, but getting to 653hp, I'm assuming the ECU must have been cracked. Good news I'm guessing for everyone that has been waiting?
    Nov 11 2021
    Atlanta, GA
    3.08 sec to 60mph with 654hp? Wondering if they are doing boost by gear and limiting down low to protect the drivetrain etc (and traction limited).
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by DarthBalls View Post
    Usually I would say yes, but it looks like in this case:
    https://www.mtm-usa.com/collections/...-8y-gpf-465-hp
    piggy back, hence why likely the TCU is limited too
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Sep 12 2022
    South Jersey
    653hp with a piggy-back? I am thinking that is over-inflated crank power and not to the wheels. Could they get that much power without ethanol with a piggy-back? I doubt it.
    Feb 09 2022
    CA
    What's with the power and torque numbers in the video?
    "653 HP - 750 NM - 360 LB FT - 480 KW"
    653 metric horsepower (PS) is 480 kw. But 750 nm is 553 lbft. Where is the 360 lbft coming from?
    Mar 01 2006
    Kitchener, ON
    ok I m not sure if their site changed, or I just completely missed it, anyway better goto the German site since its more up to date then the USA site
    https://www.mtm-online.de/en/configu...ing/RS38YL294Q
    looks like a turbo is in the list too
    Past
    Jan 07 2013
    Charlotte, NC
    wow! $40k usd installed for what is essentially a tte700 93oct power level setup. i hope that means they know they have the market cornered for the moment and not that there is an insane amount of work to get the ecu to behave. hoping the rumors of apr and unitronic developing tunes are true, need to see some 8y's out there making power
    @tuxedo.ttrs
    Aug 19 2005
    Doha
    More wallpapers:
    My Garage:
    IG: auditography
    Aug 19 2005
    Doha
    Quote Originally Posted by tf02 View Post
    It's a simple typo of 360lbft which is the stock number of the RS3. 750nm is 553lbft yes.
    My Garage:
    IG: auditography
    Aug 19 2005
    Doha
    My Garage:
    IG: auditography
    May 02 2022
    2004 Forester XT(IAG Stage 2 Tuff Block soon)
    Warrenton, VA
    Quote Originally Posted by dillybacon View Post
    I've noticed MTM is a little pricier in certain areas than others, plus you get the "AESTHETIC" package.
    Established Member Two Rings nate.co's Avatar
    May 03 2019
    Colorado
    Heh, nice to see MTM again! I had a 2000 S4 with MTM stage 2, my first Audi tuning experience. Blew up that TBB and had to replace both turbos, good times :/
    That being said, $40K is insanity
    RS3 2019 Mythos Black - DS1 flex fuel stage 2 🔥🔥
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    Quote Originally Posted by Jetdriver View Post
    You'd be right. In European countries they tend to continue to advertise using crank horsepower (BHP/PS) as they modify vehicles instead of using WHP. It seems super counterintuitive to Americans because we are so used to seeing WHP. This is a common thing even for their naming convention of products. My TC800XT was never designed or intended to make 800whp but, on a very optimized setup, it'll potentially make 800BHP/PS-ish. However, I did manage to massage 800whp give or take from my TC800XT. The same goes for the TTE855 and anything else that comes from Europe with those naming conventions on it.
    I bet you this 653bhp car likely makes somewhere around low 500's (520-540) to the wheels at best. That 0-60 seems awfully indicative of that, too.
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
    Nov 11 2021
    Atlanta, GA
    Quote Originally Posted by 8STTRS View Post
    Spot on. Also may be some boost target limiting in earlier gears for traction but overall I agree. Zero chance they are pushing 650whp on a piggyback.
    Senior Member Two Rings fzr100098's Avatar
    Nov 09 2022
    Charlotte
    Fuel is also a variable - essentially no one is pushing more than ~550 whp on 93 pump gas
    E85 needs to be rotated with normal gas to mitigate sludge buildup. Not sure I would even consider a used car running E85 unless I knew the owner well - I suspect many of these engines will look like hell after tear down
    https://www.youtube.com/watch?v=bPcVBc4-5Mk&t=539s
    There is ALWAYS a price to pay for running these extreme boost levels. A ZL1 will make ~800 rwhp on 93 pump all day. Not sure about the new M3/4
    2023 Tango Red RS3
    Aug 31 2021
    Oakland CA
    I wouldn’t use a Subaru engine as a barometer for anything
    Sep 12 2022
    South Jersey
    I'd never run a tune that required E85. Aside from the above issues no one wants to deal with in their $65k+ car, here in NJ, we don't have many gas stations that sell E85. I thought about it, but I'd have to store it in my garage in 5 gallon race jugs. I will "settle" for something around 450-500whp on 93 octane when I get my 8Y. If I get sick of that, I'll pick up a G80 M3c before BMW stops making it in 2027.
    May 02 2022
    Warrenton, VA
    Luckily where I live, e85 is plentiful. I've been e85 only the last 20-25k miles and it's been very fun. Currently have 88k miles and still going. Is there a reason you want to stay away from e85 or do you mean e85 only tunes vs a flex tune like from DS1?
    If you go Uni Stage 2 and grab all their things, 93 for me put me at 470whp at 6800 rpm, and 495wtq at 4100 rpm. Going e85 put me at 550whp, but 515wtq due to it being a stock motor. Safety limitation things. You definitely feel the difference in low end torque and spool up. Very very fun.
    Aug 31 2021
    Oakland CA
    Even with the internet panic around ethanol I’d take my chances with it over cat-piss regular gas. Detonation is bad. Maybe if I was willing to run 100 every day
    Established Member Two Rings 714RS3's Avatar
    Nov 13 2022
    Lake Forest, CA
    Quote Originally Posted by Woobachuckie View Post
    Yeah I’m in Southern California and E85 is very available. I’ve tested quite a few times and it’s only been E79-E90 content. It’s amazing and really provides an extremely noticeable power increase on a tune optimized for the e85. Even on my stage 1 e85 tune it’s insane. Been running it 10k miles and don’t see myself reverting anytime soon. The 91 gas in California is awful and being tuned on that 91 will most likely bring an issue before an e85 tune would to be honest.
    Nov 13 2022
    Lake Forest, CA
    Quote Originally Posted by lemonvr6 View Post
    100% agreed. I feel like handful of engines that failed due to stage 2 e85 tunes that pushed slightly too much torque, exacerbated the “danger” of e85. Or from the people who ran e85 too long on higher mileage cars that caused leaky injectors
    Jul 07 2018
    22 Tesla M3P
    Pleasant Hill, CA
    Quote Originally Posted by fzr100098 View Post
    Most of the zl1 guys are running e85 (or a at least some blend of ethanol) at this point
    2024 RS3 - Glacier White - PPF, Tint, ECS Intake
    *SOLD* 18 RS3 - Florett Silver - PPF, tint, Uni Stg 1+ e85/TCU stg 2, APR Intake, throttle inlet & 4in turbo Inlet, CTS Intercooler, Midpipes, fuel-it sensor, sparkplugs, ece dogbone, Uni WG Line upgrade, Eurocode Rear Swaybar w/034 endlinks, 034 Street Motor/Trans mounts, subframe locking collar kit, Neuspeed rse10s, Rotors
    2022 Tesla Model 3 Performance - PPF, Tint, cosmetic mods
    2025 Mazda CX-70 PHEV
    Jul 07 2018
    22 Tesla M3P
    Pleasant Hill, CA
    Quote Originally Posted by 714RS3 View Post
    It makes our cars so fun. The only downside is the mpg are terrible. I get like 11-13 around town
    May 02 2022
    Warrenton, VA
    I literally had this happen with my injectors. I somehow melted the teflon retainer on cylinder 4 and slightly on 2. Was causing my injector to bounce in and out of it's socket. Had the new revision injectors installed and back to the show lol. I also got a black forest report back and hlaf the engine torn down to see if there was any damage. I don't know what I'm doing right, but my engine's current "rating" would be that of a stock 25k-30k engine. But I also change my oil every 5500 miles, ceratec every 30k, and I don't push it until it's at full operating temp. But even then, that seems so little to keep it in such great shape when generally beat the hell out of it on the daily.
    Nov 13 2022
    Lake Forest, CA
    Hopefully nothing wrong with your engine. I have heard the retainers can get melted which isn’t very good. I’ve been on my e85 tune for 10k miles and I’m at 41k miles total. Thinking of putting in the new revision injectors at about 50k miles. Hopefully not melting issues until then. I do plugs/oil every 4-5k miles and don’t push until it hits operating temp either. It’s my daily as well. How did you figure out that the Teflon retainer had melted?
    Nov 09 2022
    Charlotte
    Even with the internet panic around ethanol I’d take my chances with it over regular gas. Detonation is bad. Maybe if I was willing to run 100 every day
    No detonation near stock boost levels
    I wouldn't call it panic, E85 leaves sludge/deposits in the engine that aren't noticed until you actual tear it down. If you're not planning on keeping the car a long time maybe it doesn't matter, but I won't be buying a used car with significant E85 use now and I expect these modded cars are going to take more of a hit in resale value
    Lots of 600+ hp claims out there, but not many second hand buyers
    2023 Tango Red RS3
    Jul 28 2021
    Navarre, Florida
    I make it a habit to run some pump gas through my car. But, I don't think I'm your typical owner. Not only do I actually keep up on my maintenance, I also don't dog my car. I daily it and have made maybe less than 20 full pulls on it since the build was completed over a year ago. It's mostly just seeing regular commuting and every once in a blue moon, some spirited driving--even less frequently, it'll see a full send. But when I do race it or send it, I typically also log it and send the logs to my tuner for him to ensure everything is good to go. Even on full pump gas, I'd wager the car is making around 550-600whp. I don't need the extra 200-250whp while I'm just putting around town or heading into work. While I enjoy it, I know that the more I ask of it, the quicker it'll wear down and need to be refreshed. The build done on my car and my wife's car was prefaced around the fact that these would still be our daily drivers.
    2018 Audi TT RS
    Aug 31 2021
    Oakland CA
    Factory tune on gasoline has a ton of timing correction. What do you think initiates that, exactly?
    Sep 12 2022
    South Jersey
    The ability to run with 91 octane and different qualities of fuel. I think the difference between 91 and 93 octane in the 8Y is at least 20whp.
    Nov 09 2022
    Charlotte
    I'm not sure you have a point, yes modern ECUs all incorporate knock sensors with varying degrees of sophistication - my point is detonation isn't going to happen running quality 93 pump gas (I only run Shell 93) at stock boost levels. The "cat piss" comment sounds like something an insecure 22 year old punk kid would say
    Many people don't have access to E85, and don't want to deal with corrosion and/or sludge accumulation issues - run at your own risk. Rotating it is probably fairly safe but it will reduce engine longevity
    2023 Tango Red RS3
    Jul 28 2021
    Navarre, Florida
    I know we've spoken extensively but, he's not inherently wrong. Even with quality 93, at least on the 8S TT RS and the 8V RS3 (things might be different for the 8Y), the car will simply pull timing. This is why a lot of folks, even car reviewers, will put ethanol into the tank on a pump gas tune or stock tune to get the car to stop pulling timing. Now, how much power is being lost? I guess that depends on the quality of the fuel at hand but, it's been a well know thing with these cars. There's plenty of logs/documentation that covered this issue but, the vast majority of people would probably not even notice it--essentially saying that the power difference may be negligible to most but still present nonetheless.
    2018 Audi TT RS
    Aug 31 2021
    Oakland CA
    I wouldn’t evaluate timing correction only through the lens of reduced power. On the stock turbo, shorter OCIs are well worth it for the benefits of oxygenation and a basically knock-proof fuel
    Or you can batter your rotating assembly pushing the edge on unleaded. Not my car.
    Feel free to refute with something other than a garbage Subaru engine that was treated improperly
